#161 (permalink) | |
Paid Member
#162 (permalink) |
LOL, I don't watch to much TV these days.
Yes the VC-25 would be correct for blow through setup. Else if you want exact control check out the new VCS3G - Water-Meth fueling computer. http://www.labontemotorsports.com/st...how/VCS3G.html Best regards, Dan
Labonte MotorSports
Performance Water-Meth Injection Systems since 2002 1-815-315-4823 www.labontemotorsports.com sales@labontemotorsports.com |
#163 (permalink) | |
Racing
#164 (permalink) | |
Corn Its whats for boost
thanks chris
AEM Factory Trained Tuner
![]() 91VR4 Black-5027s-3.0L-Stock heads and Cams- 707AWHP 620AWTQ uncorrected 30psi E85 Daily Driver SLTT-10.9 @ 140MPH Stock NA motor and NA heads/Cams T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L C16 T2-820FWHP 3.1L 27psi C16 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-sold 3SX Performance 3SX Performance Service Email |
#165 (permalink) |
Forum user
Did you guys ever hash out the pros n cons, in an apples VS oranges fashion? I'm a big fan of water meth for its charge cooling propperties, and even if your dirt poor, between the isles of a hardware store that sells welding supplies and an NAPA, you can put togather your own primative system on the cheap.
Which is another thing, the all important HP/Dollar ratio. Shouldn't this be a part of this great comparison? For my technical inquery, isn't propane technically a dry fuel, and as such, it has less effect on the charge temp in comparison to ohh say, water, meth, alcahol? From my view, propane has some basic advantages, VS dumping more wet fuels, in that its easier on the lubricated parts by not washing the cylinders walls and burning cleanly. Its downfall I would think is the install costs. The cheapest kits I've seen start around $600.00 ![]() I've also read some misguided woes about them blowing up, yea, if the cars already on fire. The last I read, propane tanks have a higher puncture resistance than gasoline tanks. With a propper bottle/electronic safeties, say, ohh, like what is used on N20 systems, it could be just as safe. I don't see nitrous as a even being a knock deterent, in any way period. Most of the time you end up adding fuel to the system to prevent it from causing detonation. You don't have to come up with dyno charts and knock count graphs to figure out water/meth/alcahol work, and work well. Its nothing new, water kits, (be it by small and unheard of companies) were produced for draw through k-based chryslers way back in the 80s. Why it has just now become mainstream in the camaro/mustang world in the past 5-10 years is beyond me. I'm by no means a genius, I don't think I have anything to add but basic perspective and simple science, but thats why I'm reading this, to learn from you guys and exchange ideas on the topic. So, where's the pro's/cons list?
![]() Ernest. |
#166 (permalink) | |
rock on, yeah rock on
i don't remember what ipo used to sell his kits for, but it was less than $600. i know DR used to sell a kit. don't remember the specific cost, but i believe it was under 600 as well. and after that, propane is relatively cheap to refill, as is meth/water. as far as results, i don't have the webpage offhand, but i remember ipo did some tests with a datalogger a few years ago on a 17g vr4, and knock was all but eliminated. i don't remember the specifics of the test as it's been a year or two since i visited that page.
Dyno Collection Thread
1993 Dodge Stealth ES, White, April 2002 - April 2005, SOLD 1 of 53 1993 Dodge Stealth TT, Black, Since April 2004, 1 of 5 ever made more rarity info 2003 Subaru Forester 2.5X, Blue, Sept. 2005, Daily Driver with 165 HP of Fury! At least it's AWD. ![]() ![]() ![]() 305 awhp, 325 awtq(BPU minus full catback exhaust)Mods at that time 13.02@104.67 (9bs, dp, fipk, 15.5 psi, bov, no cats, streetmax clutch, 1.77 60', decent conditions, full weight (even spare tire/jack) 13.09@105.08 (1.80 60', same conditions as above) Beyond BPU: (meaning upgraded turbos/fuel/etc) before engine rebuild Mods at that time 12.38@113.00(20 psi, 110 octane, massive knock above 6k rpms) 12.41@115.10(ditto) After Rebuild: Current Mods Dyno Tune by IPS 12.8@108 (12.5 psi dropping to ~11 @redline, 2.0 60', pump gas, my tune) |
#167 (permalink) | |
Member in good standing
You seem like a well organized person perhaps you would do us the honor of setting that up. ![]()
