#151 (permalink) | |
Racing
#152 (permalink) |
never a dull moment
also a nice thing about propane is if you want to add more you up the pressure its being forced in at. No need to go buy a bigger pump or nozzels ext.
Coop
![]() To many mods to list. |
#153 (permalink) | |
Jim Berry
Don't believe everything you think ---- fastmax
#154 (permalink) | |
Corn Its whats for boost
AEM Factory Trained Tuner
![]() 91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph SLTT-10.9 @ 140MPH Stock NA motor and NA heads/Cams T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L C16 T2-820FWHP 3.1L 27psi C16 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-sold NG09 Title Sponsor 3SX Performance 3SX Performance Service Email |
#155 (permalink) |
Certified White Boy
aight, so approximatly how much boost can propane allow you to add? is it safe to run on a stock motor?
"Clutch-Eater"
-1992 Dodge Stealth R/T Twin turbo AWD, Dynamic Racing stage II heads, 99 lifters, 6-speed Getrag from 99 vr4, SPEC Stage 4 clutch, TEC 15g's, Greddy blow off valve, Dejon Powerhouse Blow-Thru Intake Pipes, DSM sidemounts, Denso fuel pump, 550cc fuel injectors, Apexi SAFC, HKS VPC, Apexi AVCR, msd ignition dis-4, MSD 8.5mm wires, NGK coppers 1 stage colder, alamo y-pipe, custom exhaust from turbos back, highflow cat, Lowered, Nitto tires. "Knockin' Beater" -1996 Mitsubishi Eclipse GS |
#156 (permalink) |
never a dull moment
yes safe to run on a stock motor, boost depends on intercoolers, turbos, tuning, and how much propane you want to add. Search up old results from this because there was a following for a good little while.
Coop |
#157 (permalink) | |
You need one of the controllers to drive it. We do it this way so the system is more modular. With all the different mods people have it is difficult to have a complete system. This allows for the selection of the controller that is right for the engine. It also allows for lower stocking requirments for your dealers. For example the VC-25D is a design specific for the Mitsubishi. But if the MAF is removed for a Blow Through setup, the VC-25 would be all that is needed. As far as boost I was running 17psi on my stock 9Bs with water-meth. Others on here have run much higher boost with the systems. Best regards, Dan |
#158 (permalink) | |
What does the controller do that On/Off doesn't? I am asking because I am starting my engine build to finally mod my VR4 and going EVO3 I want to run high boost (mid 20's) on pump and I figure a good meth kit would allow me to do that. And I am using an AEM so I can configure an output to do whatever. |
#159 (permalink) | |
Racing
#160 (permalink) |
The amount of intake cooling and detonation control needed at low boost is not the same at higher boost levels. For example: Lets say the car is running 26psi and makes 450rwhp. For water-meth you would need about 570ml/min with this set up. If using an on/off switch you will get full flow at the onset, lets say 10psi activated with Hobbs switch. But at 10psi hp is lower say 300 at that point, so you only need 300ml/min. Injecting 570 at 10psi would be to much fluid and hp will drop some from combustion quench.
The variable controllers regulate the injection amount based on the load of the engine. This allows for maximum hp gains across the entire RPM band. The controllers actually send a PWM signal out to the pump to regulate pressure. Min pressure is 60psi to get good atomization of the fluid out of the nozzle. As the engine load goes up, so does the signal to the pump to increase pressure. More pressure at the nozzle results in more flow. Our controllers have been designed to account for the non-linear characteristics of the pump-pressure-flow dynamics. This provide the best possible injection curve for the controller resulting in flatter A/F curves, and easy tuning. We keep our systems simple for wiring, install and tuning. The basic design is set and forget. Once it is set, forget about it and make the power you want without expensive race gas. Best regards, Dan |
