Old 08-18-2005, 06:57 AM   #141 (permalink)
Banned from Classifieds
lightweight's Avatar
Drives: HiBoostRacing.com
Trader Rating: (58)
lightweight is an unknown quantity at this point
Default Re: Alcohol vs. Nitrous vs. Propane vs. Water
I know personally of a customer of mine with my Lightweight Boost Injection kit that is running a 90/10 mix denatured alcohol/distilled water and can run about 28psi, on pump. and is only tuned with an arc2
lightweight is offline   Reply With Quote
Old 08-18-2005, 07:48 AM   #142 (permalink)
Pro xfercase destroyer
mjannusch's Avatar
Drives: 2005 Toyota Prius
Trader Rating: (20)
mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7
Originally Posted by SHiVeR-91VR4
wideband is probably a good idea when you start getting into this territory.
If you add meth, you still want to stick it right where you have it. You don't want to tune it leaner, unless you're on race gas.
So tune pump to 11.5-11.8:1
Start spraying meth. You should see your o2's get increasingly rich with the more meth you add.
Tune your car back down to 11.5-11.8:1 and then you can start leaning it out a bit to see if that helps.
Yeah, when I tried this it was about 4 years ago and I gave up on it since I didn't get results. Widebands were still reasonably exotic at the time. If I see some positive results, I may try it again with a more sophisticated injection system triggered off my AEM. I'm rapidly running out of space under the hood for tanks and such though.
-Matt
'95 3000GT Spyder VR4 (11.838@117.56)
'93 3000GT VR4 (Project for 2009)
'91 3000GT VR4 (Only a shell of its former self)
mjannusch is online now   Reply With Quote
Old 08-18-2005, 07:27 PM   #143 (permalink)
Drives: 1994 VR-4
Trader Rating: (16)
dlabonte Level 1dlabonte Level 1
Originally Posted by slava
Since we can not accurately spray the amount of water/meth just enough to supress the detonation at each (RPM/Boost point)you are going to loss power unless you substitute with boost. As far as 30psi supra guys running it they do with almost 50% of methanol in fuel mixure. I read many post about on supra forum started by Derek.
The combustion engine power comes from expended gases and the less temperature on the intake and MORE on the output the more power engine makes. you lower temperature unneccessary and you are lossing power.
I have a W/M controller that uses the stock 3/S Karman signal and boost pressure to control injection. Works great so you don't over inject and loose low and mid range power. Also have one that uses a 0-5volt signal that could be used with AEM. Would do $109 shipped (List is $129 + shipping) to 3Si members.
There was an EVO featured in Turbo magazine last month that was doing 30 something psi with W/M. They called it the ultimate tunner cheat (LOL).
Which turbos available to us would flow 30psi to redline? That would be alot of power, can our transmissions take it?
Matt:
There are a number of tank options for you. Can put a tank in the trunk or behind rear seats. Mine is the 99 overflow tank that mounts under the front bumper, it is only 1.5qts. European version is full gallon. (yep great more weight for the front)
Dan Labonte
dlabonte is offline   Reply With Quote
Old 11-12-2005, 03:26 AM   #144 (permalink)
Member in good standing
Jim Floyd is an unknown quantity at this point
Default Alcohol vs. Nitrous vs. Propane vs. Water
Anyone else have anything else to add?
Jim Floyd is offline   Reply With Quote
Old 11-12-2005, 06:41 AM   #145 (permalink)
Drives: 1994 VR-4
Trader Rating: (16)
Hey Jim, do you have much snow yet? Meeting Racer Boy at Summit Point next weekend.
Did you get the W/M kit installed yet? If so how is it working for you?
Best regards,
Dan
Old 11-12-2005, 07:27 AM   #146 (permalink)
Best regards,
Dan
It has snowed very lightly twice, but did not stick.
It's not in yet. We are installing the roll bar first so we will know where we can mount the tank for the kit. Ryan Smith is going to put it in for me.
Old 12-26-2005, 12:00 PM   #147 (permalink)
92R/T's Avatar
Drives: 92 R/T TT
Trader Rating: (19)
92R/T is an unknown quantity at this point
what type of setup/turbos?
Bump
www.somersetunderground.com
91 Stealth ES
92 Stealth R/T TT
95 Stealth R/T - totalled
95 Stealth R/T TT
92 Talon
88 Daytona
92R/T is offline   Reply With Quote
Old 02-19-2008, 11:42 PM   #148 (permalink)
Certified White Boy
92stealth15g's Avatar
Drives: 1992 Stealth RT/TT
92stealth15g Level 392stealth15g Level 392stealth15g Level 392stealth15g Level 3
So, im really going to wake up a dead thread. I hope nobody gets mad... So is propane really that dangerous..? can it backfire and blow up? Hell, if we are going to inject dangerous and combustible things into our cars why not just use oxy-setaline. haha..
"Clutch-Eater"
-1992 Dodge Stealth R/T Twin turbo AWD, Dynamic Racing stage II heads, 99 lifters, 6-speed Getrag from 99 vr4, SPEC Stage 4 clutch, TEC 15g's, Greddy blow off valve, Dejon Powerhouse Blow-Thru Intake Pipes, DSM sidemounts, Denso fuel pump, 550cc fuel injectors, Apexi SAFC, HKS VPC, Apexi AVCR, msd ignition dis-4, MSD 8.5mm wires, NGK coppers 1 stage colder, alamo y-pipe, custom exhaust from turbos back, highflow cat, Lowered, Nitto tires.
"Knockin' Beater"
-1996 Mitsubishi Eclipse GS
Originally Posted by TitanGenesis View Post
"That thing got a hemi?"
"No, it's got a V6 TT with AWD sup?"
92stealth15g is offline   Reply With Quote
Old 02-20-2008, 04:53 AM   #149 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (210)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
We already inject dangerous and combustible things into our engines, it's called gasoline. And it's sitting in large amounts in a thin metal tank that can easily be punctured by hand with a screwdriver. Try that to a propane tank.
Propane tanks are already installed in many municiple vehicles that have been converted including police cars. Most Camper/RVs, many personal LPG cars/trucks. You don't see them running around exploding left and right.
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 02-20-2008, 08:00 AM   #150 (permalink)
Drives: 1994 VR-4
Trader Rating: (16)
Wow it was 3 yrs ago that I posted in this thread. Hope Jim has his system installed by now.
Not many worries about propane back firing, I did see a post a while back where a Noz tank blew up and took out a guys garage. But that is very rare.
Propane can help, but Water-Meth injection will lower IAT more and is safer, IMO.
Water-Meth is octane on demand, more HP on pump gas. With our new Injection Fail Safe, IFS-10, it is very reliable.
Best regards,
Dan
