#111 (permalink) | |
Dan |
#112 (permalink) |
Just thought I would mention here that I am using Water Injection (coolingmist) & it has enabled me to increase my boost from a safe 15psi to 20psi safely on 91 octane fuel. I have 15G's & all supporting mods + Haltech E6K engine management.
Keep the discussion going...very interesting & informative. Regards, Edmund
JDM VR4's
#113 (permalink) | |
Mmmmm, Boooooost!
I still think that if you gain say 17hp/psi without w/m, that # will drop if you require it to run increased boost. yes, you'll be making more HP than without it, but doesn't this seems like a tuning bandaid rather to anyone else (and not just w/m, but propane, too)? From what i learned while i was working along side some Japanese supertuners at my previous place of employment, none of them use w/m injection, or any other knock supression tool for that matter, only tuning. Proper products, boost, timing, and a/f all in concert to play a fantastic tune to the order of the best feeling car, not necessarily the fastest or highest HP# posting car. |
#114 (permalink) | |
Also, this does not increase HP ONE BIT AT ALL. It REDUCES HP. All it does it allow you to run more boost and get more useable HP that you currrently can't use because of octane. If you're running pump + water injection at 30psi lets say and you have 700 HP. If you switch to straight race vp16 and run 30psi, you will GAIN LOTS of HP. In supras I have seen a jump of ~75 HP at the 700HP levels. They would dyno 600 on pump (limit of octane), 700 on pump + meth, and 775 on race gas. It's just a cheap way of not having to buy race gas, but getting more than what pump gas can offer. At the track, I would personally still use leaded vp16.
#115 (permalink) | |
That's all it is, is a bandaid....and a VERY nice one. It saves 2-3 times the cost of gasoline and you get 90% of the power you could with race gas. It's a nice mod if you have big turbos and want to run 20+ psi on the street, but don't want to drain $150 worth of race gas every fillup. My big question is still on how much is too much. I'm going to run 50/50 meth/water that I will mix, and I was thinking of getting the ~7gph ~= .12gpm nozzle. The supra guys I see use the .2 gpm nozzle for starters, so I'm thinking .12 might not be enough. |
#116 (permalink) | |
97'vr4
#117 (permalink) | |
Banned from Classifieds
Why would you NOT feel a gain from 15-20psi...as long as you are within the turbos power range, the air will be cooler, which in turn creates more power. It has been my own finding as well as others, that injecting higher concentrations of alcohol as compared to water can produce more power. This is due to the fact alcohol BURNS and water STEAMS. They both offer detonation control, but the higher octane produced by alcohol, allows for far superior horsepower production.
#118 (permalink) | |
#119 (permalink) | |
The only way to setup AEM to do duty is to use boostcontroller function or possible VTEC. But sounds too good, 50% duty = 50%spray ...but I am sure it is not. Does anybody have the table Duty vs spray volume? it is not linear . or duty vs pump presure vs spray volume. Those things are important to correctly measure the amout of spray. I hope our vendors can provide some information. What is good about variable controller if i do not know how much meth i am spraying vs pump duty cycle. That also would change with different nozzle size. |
#120 (permalink) |
660cc fuel injectors here and absolutely NO bog. Matt M. or Dan L. should be able to tell us what size nozzle comes with the kit that Matt is selling. And if I remember correctly the w/m controller is set to come on full at 8psi of boost on my car. DR could look at my car to double check that.
