#92 (permalink) |
Pro xfercase destroyer
So does anybody have ANY sort of measurable results from this?
The closest I'm seeing is this "amazing" set of datalogs: ![]() ...which look to me that the car accelerated about as well in 3rd gear without water as it did with water. Anyone have back-to-back dyno runs with their best tune without water/alcohol/propane/whatever and then another pull with their injected fluid of choice that actually shows a clear power gain?
-Matt
'95 3000GT Spyder VR4 (11.838@117.56) '93 3000GT VR4 (Project for 2009) '91 3000GT VR4 (Only a shell of its former self) ![]() |
#93 (permalink) |
Here are the numbers I collected from the manufactures MSDS reporting % Methanol (plus other stuff in some cases)
Manufacture Product Metanol % Camco -20 < 35 Peak -20 < 33 Peak -25 < 35 Peak -30 < 36 (<5 Propylene Glycol) Prestone De-Icer 30-60% (3-7% Ethylene Glycol) As you can see the manufactures are not even sure what is in their product, so no guarante what you are always getting. Best regards, Dan Labonte |
#94 (permalink) |
Corn Its whats for boost
i posted the logs of the with and without propane many moons ago showing a large decrease in knock.
AEM Factory Trained Tuner
![]() 91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph SLTT-10.9 @ 140MPH Stock NA motor and NA heads/Cams T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L C16 T2-820FWHP 3.1L 27psi C16 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-sold NG09 Title Sponsor 3SX Performance 3SX Performance Service Email |
#95 (permalink) | |
Check out www.snowperformance.net for some dyno runs and world records set with Porshe and diesel dragster. Here is a quote from Tommy Williams who I sold a Stage-II kit to last fall in a GB: "Dan - I'm not sure if I showed this to you before but my EGT's have been consistently below 200 degrees Celsius when spraying a w/m -35 degree mix [see attached]. I dyno'd with the current setup and produced 467 AWHP. again, I'm running TEC 15G turbos, Denso 660cc injectors, PRO-M 80mm intake and MAFTuner for fuel control @ boost of 22.5 psi. I don't think my EGT sensor/setup is off and all components are still relatively new. I can't really say how low the EGT's went since my minimum measure 200C but clearly I achieved a greater reduction than 200. " I will email him and see if he has some dyno results to share. Dan Labonte |
#96 (permalink) | |
Can anyone show measured results on a 3/S car? ...and I'm not talking a pull where the car is knocking like crazy on the pump gas only - I'm talking clean well-tuned pulls on both setups. |
#97 (permalink) | |
#99 (permalink) | |
