Old 11-07-2008, 09:29 AM   #1 (permalink)
triple8zn is an unknown quantity at this point
Default Will these rims fit?
i want to use these rims for autoX and was wondering if they would fit, there off a 2006 niss 350z touring
i have a 92 vr4 w/ front spacers thx.
Front
Offset: +30mm
Weight: 24.4
Tire: 225/45/18
Rear
Offset: +33mm
Weight: 25.8
Tire: 245/45/18
triple8zn is offline   Reply With Quote
Old 11-07-2008, 09:32 AM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
Default Re: Will these rims fit?
The rims will probably fit, but you shouldn't run those tires on your car.
On our AWD setup the VCU can't see more than a 1% difference in O.D. between the front and rear. Those tires are 2.7% different.
Also, stock tire size is 245/40/18 on 2nd gens. A 45 sidewall means that tire would be too tall. Additionally, a 225 wide tire on the front is too narrow. It's too narrow for normal driving - and it's especially too narrow for autocross.
R.I.P.
Old 11-07-2008, 09:37 AM   #3 (permalink)
thx. i already have the set of rim with tires and was wondering how i can use them. so would i put the wide ones in the rear or front, what would drive better, the event is only 1:30 hours away
Old 11-07-2008, 09:40 AM   #4 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
If you drive with those tires on those rims on your car, you will probably fry your VCU and need to rip the tranny out and apart to fix it.
Old 11-07-2008, 09:42 AM   #5 (permalink)
glad i asked the second question, thanks for the help. can i use one of the tires as a spare
Old 11-13-2008, 03:49 AM   #6 (permalink)
BillGezon is an unknown quantity at this point
Can someone define VCU please? words like variable center and viscous come to mind but I cant figure it out.
BillGezon is offline   Reply With Quote
Old 11-13-2008, 08:10 AM   #7 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
The Pansy Patrol More than you ever wanted to know about AWD
