Old 04-02-2008, 07:33 PM   #1 (permalink)
3000GTVR41994's Avatar
Drives: 08 Eclipse RIP VR-4
Trader Rating: (11)
3000GTVR41994 is an unknown quantity at this point
Default Will these fit my 94 VR-4?
Hey, looking at buying these rims for my 1994 VR-4. Will they fit? I think they will based on what i can find but i want to be sure.
http://www.discounttiredirect.com/di...8.5&bp=5-114.3
Mod List: K&N cone, DNP Y-Pipe, TurboXS RFL BOV, Custom down pipe and full 3" exhaust, Apexi AVC-R Boost Controller @ 15PSI, Apexi SAFC-II, 450CC DSM Blacktop Injectors, MSD 8.5MM wires w/ NGK copper plugs, Spec Stage 2+ clutch, RPS Billet Flywheel, Custom stereo system, Seibon Carbon Fiber Hood, Enkei 18"x8.5" RZ-5 wheels w/ Falken Ziex 912, AEM WB 02, HHH Hybrid Logger w/ wideband integrated, VAC reduction, EGR delete w/ blockoffs, Mcculloch 10,000K HID low beams
3000GTVR41994 is offline   Reply With Quote
Old 04-03-2008, 04:19 AM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (61)
Default Re: Will these fit my 94 VR-4?
Those look like they should fit, since the +38mm offset and spoke design look good for brake caliper clearance ... but there's only one way to be sure and that's to test fit them.
2002 WJ -- 1994 VR-4 -- Canon Rebel XTi
Originally Posted by Kenneth Ellis View Post
Every one of you are fools, each and every one.
Old 04-03-2008, 06:42 AM   #3 (permalink)
Trader Rating: (11)
Thanks lawdogg, i just want some solid confirmation...for me that is quite a bit of money and don't want ones that won't fit. may give the website a call and see what their thoughts are.
Rob
Old 04-03-2008, 07:40 AM   #4 (permalink)
J0hnC14rk's Avatar
Drives: (s)low
J0hnC14rk Level 4J0hnC14rk Level 4J0hnC14rk Level 4J0hnC14rk Level 4J0hnC14rk Level 4
I shit you not, I'm thinking about getting the exact same wheels (only in the silver color) for my '98 SOHC.
http://www.discounttiredirect.com/di...=18&vid=006329
You sir have good taste and financial sense!
J0hnC14rk is offline   Reply With Quote
Old 04-03-2008, 08:36 AM   #5 (permalink)
Trader Rating: (11)
Yea lol thanks. Problem is I want to be 100% sure they will clear 2nd gen VR-4 calipers. I will give them a call when i get off work and see what they have to say.
Rob
Old 04-04-2008, 05:40 PM   #6 (permalink)
Trader Rating: (11)
Here are the ones i chose since the ones i wanted wouldn't fit.
Got em coming wrapped in Falken Ziex ZE-912 245/40/18
