Old 05-23-2008, 09:49 AM   #11 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (65)
Default Re: will saleen replicas 18x9 24 mm offset fit 91 TT
I believe both offsets have the same outer spoke conavity ... right?
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 05-23-2008, 10:17 AM   #12 (permalink)
Kibwe Walker's Avatar
Drives: 93 RT/tt
Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7
so none of the saleen replicas fit flush?
I don't want it to stick out the front at all, the back looks good with wider rubber but I don't like the front taht way.
Also I will only get rid of the stock 93 chrome for some lightweight 5 stars, how much do these replicas weigh?
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer.
Hers - BPU Green 94 vr4
Kibwe Walker is offline   Reply With Quote
Old 05-23-2008, 10:39 AM   #13 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (65)
Kibwe - I believe we weighed my gf's at ~26-28lbs. each, I forget which but it was in the mid to upper 20's for sure.
Old 05-23-2008, 11:25 AM   #14 (permalink)
i'm ridin big yo
1bad3grs's Avatar
1bad3grs is an unknown quantity at this point
yes.
1bad3grs is offline   Reply With Quote
