Old 04-23-2008, 12:49 PM   #1 (permalink)
Drives: 1997 VR-4
tonyvr4 is an unknown quantity at this point
Default wheel width on VR-4
I need to replace the wheels/tires on my 1997 VR-4 and some of the wheels I have found are narrower or wider than stock and I was wondering what the widest I could safely put on there, using the same size on all 4 corners ?
Some wheels are 8" width, and remember the stock wheel was 8.5". Also some wheels I found are 9.5 and although this may give me the option of a wider tire would it fit on the front ?
Thanks
Tony
tonyvr4 is offline   Reply With Quote
Old 04-23-2008, 01:02 PM   #2 (permalink)
modding addicted
Turbo Powered's Avatar
Drives: at high g's
Trader Rating: (26)
Turbo Powered is an unknown quantity at this point
Default Re: wheel width on VR-4
Geez, do you really need 4 threads for the same subject, wheels and tires?
There's a sticky at the top of this section on rims that fit TT/VR-4.
The 5Zigens are a popular wheel, come in 18 x 9.5 that fit. ICE888 sells them, here's a thread in the group buy section:
http://www.3si.org/forum/f25/5zigen-...le-now-293620/
Yes, the Proxes 4 are decent tires. Searching is your friend (with the right spelling). Here is a thread asking about them recently:
Toyo Proxes 4 tires, they any good?
Turbo Powered is offline   Reply With Quote
Old 04-24-2008, 10:18 PM   #3 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Struggly Level 1Struggly Level 1
You can put whatever you want on there so long as you have the measurements right. 9", 10", 11", whatever (though judging from your posts you don't need a serious wheel size).
Read this article on wheel fitment. It'll help you understand how to choose wheel sizes and offsets: The Pansy Patrol » Backspacing, offset, and buying aftermarket wheels
EDIT: Turbo Powered, are those the esses at the Glen in your sig?
Clint
The Pansy Patrol
1994 Mazda Protege DX: 260K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it
Struggly is offline   Reply With Quote
Old 04-25-2008, 01:09 AM   #4 (permalink)
Praise RaptorJesus!
sammage's Avatar
Drives: bugeye wagon
Trader Rating: (25)
sammage is an unknown quantity at this point
Anything less than stock width is a ricer size, and therefore detrimental to performance...I would definitely check out ICE888, as he is good people to deal with, and has great prices.
Originally Posted by Predacon View Post
PS. Everyone be nice in this thread, mean people suck!!!!
sammage is offline   Reply With Quote
Old 04-25-2008, 03:48 PM   #5 (permalink)
modding addicted
Drives: at high g's
Trader Rating: (26)
Originally Posted by Struggly View Post
EDIT: Turbo Powered, are those the esses at the Glen in your sig? Clint
Yes, one of my favorite parts of the course.
Old 04-25-2008, 03:51 PM   #6 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
I'm going to be there Monday and Tuesday for an HPDE.
Clint
