Old 05-04-2008, 06:05 PM   #1 (permalink)
Drives: 3000gt & VFR750
YoshiHNS is an unknown quantity at this point
Default Wheel size for 3kgt NA
Looked around but could only find info for VR-4. Looking at replacing the wheels for my '93 gt. I have 16" Miglia MII's on my 94 gt and I love them. Would like to get 17" for the '93. I found a set of Mille Miglia A1's, but I'm not sure if they will fit, and finding Miglia's is tough. They are off an 06 Audi A6. 17x8J, bolt 5x112, offset 35?. I did a search on tirerack for wheels and it seems that the correct size should be 5x114. Will those 2 mm make a difference? Assuming so, but would like some confirmation.
Also, any chance this could get updated? Would be a lot of help to more people than just me
YoshiHNS is offline   Reply With Quote
Old 05-04-2008, 06:14 PM   #2 (permalink)
i can make your vtech cry
turbosprentice's Avatar
Drives: '96 3000gt(base)
turbosprentice is an unknown quantity at this point
Default Re: Wheel size for 3kgt NA
it's best if you get 5x114.3. i remember putting on 5x100 just to try it on. it didn't even line up with my lugs. so i'm guessing it'll be the same with 5x112. there are also a lot of rims that will fit our n/a's. just make sure the offset is close to the stock. most people here have said between 35-43. but our stock offset is 46. so i'm not sure myself either. i went with 38. also, there aren't a lot of rims with a deep dish that will fit our cars either. gl though.
turbosprentice is offline   Reply With Quote
