Old 06-07-2005, 04:56 PM   #41 (permalink)
Trifler's Avatar
Drives: '97 3000GT VR-4
Trifler is an unknown quantity at this point
Default Re: WHEEL LIST - Rims that WILL fit a TT/VR-4
Ok. It just depends on how much that peace of mind means to you. I also found the price of the store to be comparable to buying online after subtracting the cost of shipping and sales tax for my state, so I didn't have any incentive to buy wheels online.
Volk Racing 18x9.5" LE-37 Wheels, Yokohama 275/35 dB Tires, JIC Coil-Over Struts/Shocks, Supercar Engineering Tender Springs, PST Carbon-Fiber Driveshaft, K&N FIPK Air Intake, DN Stainless Air Intake Pipes, Ultimate Performance Cold Air Box, TM Rear O2 Sensor Housing Eliminator w/ceramic coating from Swain Tech, Pit Road M 80mm Twin Flex Downpipe w/ceramic coating from Swain Tech, Random Technology 3" Ultra-High-Flow Catalytic Converter from 3SX Performance, Custom 3" Cat-Back Exhaust, 2 Flowmaster Universal High-Flow Mufflers, GReddy Type-S Blow-Off Valve, Supercar Engineering 14.5" Front Brake Kit with 6-piston AP Racing Calipers, Carbotech Bobcat Brake Pads, 3SX Silicone coated SS Braided Brake Lines, Saner Front Sway Bar, Quickor Rear Sway Bar, TurboXS Manual Boost Controller
Trifler is offline   Reply With Quote
Old 06-07-2005, 10:43 PM   #42 (permalink)
9B WEAKSAUCE since 2001
undertaker's Avatar
Trader Rating: (13)
undertaker is an unknown quantity at this point
Ok, thanks for the info.
undertaker is offline   Reply With Quote
Old 06-09-2005, 12:31 AM   #43 (permalink)
15t's ... ? yep
DigiiManDan3KGT's Avatar
Drives: 80Gig WesternDigital
Trader Rating: (7)
DigiiManDan3KGT is an unknown quantity at this point
whats the cheapest 5 spoke or duel 5 spoke design that wieghs under 20 lbs? ?
Green 1995 3000GT // 15t Turbos // ATX to MTX // NA to TT // FWD to AWD // Purchased 11/12/02
White 1999 3000GT Black Dash/Tan Leather Interior // SOHC // MTX // Stock Daily Driver Purchased 7/25/07
<-- Click Here Join FL3S
DigiiManDan3KGT is offline   Reply With Quote
Old 06-09-2005, 12:51 AM   #44 (permalink)
Watch this.
Red92vr4's Avatar
Drives: '94 Stealth TT
Red92vr4 is an unknown quantity at this point
I believe the Axis Reverb is about 20 lbs. It is a 5-spoke, and the spokes are hollow. It is available in gold w/ machined lip, black w/ machined lip, or anthracite (gray) w/ machined lip. It is also available in 18" x 8.5", or 18" x 9.5".
Originally Posted by agentoblivious View Post
You know what I don't get? Why someone would name a brand of condoms Trojan. Because to me trojan reminds me of the trojan horse....and who wants a condom with a trap door where *suprise!* its not a real condom its an invasion!
Red92vr4 is offline   Reply With Quote
Old 06-09-2005, 09:30 AM   #45 (permalink)
15t's ... ? yep
Trader Rating: (7)
Those look pretty good. I couldnt find any confirmation on wieght though.
Old 06-09-2005, 05:47 PM   #46 (permalink)
Watch this.
Red92vr4's Avatar
Yeh, I just guessed on the weight because there really isn't a whole lot to these wheels.
Old 06-14-2005, 11:07 AM   #47 (permalink)
I'm a Troll
Drives: too many 3/S cars
Trader Rating: (24)
Hans91GT is an unknown quantity at this point
Enkei rp-01 17x9 with a 38 offset will fit both 1st and 2nd gen TT's. The 18x9.5's with a 45 offset only fit the rear. They will fit the front with spacers, but will hit the strut without them.
Pic of the 17's.
Hans91GT is offline   Reply With Quote
Old 06-14-2005, 01:08 PM   #48 (permalink)
Fidel Cashflow
SkortchGT's Avatar
Drives: 1992 3000GT VR4
Trader Rating: (13)
SkortchGT Level 1SkortchGT Level 1
(see sig) 5ZIGEN FN01R-C's in 18x8.5, 30 offset. Fit perfectly with no issues. Got them from Hans @ GZP. Good price.
1992 3000GT VR4
--Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579
--First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, cat back & CFDS, time for another dyno run soon)
--Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, PST 1pc CFDS, Borla Catback, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, engine dress up kit, Bigtyla ground wire kit, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset.
--Waiting for me to install: ARC2 w/ 92mm MAS
--Daily Driver: 2000 Malibu, 6cyl, auto
SkortchGT is offline   Reply With Quote
Old 06-14-2005, 09:27 PM   #49 (permalink)
3S Obsessed
HydeDW's Avatar
Drives: 97 VR4
Trader Rating: (11)
HydeDW Level 2HydeDW Level 2HydeDW Level 2HydeDW Level 2HydeDW Level 2
Pic of the 17's.
"They will fit the front with spacers, but will hit the strut without them."
but clear the front strut if running Tein Flex in case someone has that combo. At least 3mm spacers required in front with stock struts
Dan (3SI #37)
Pearl White 1997 VR4 (117K 4/2007)
Engine: 13T Turbos - Rob Beck engineered
Engine: AEM EMS; GM 3.0 MAP, GM IAT, GM EBC, RC550's
Intake: Dejon Hardpipes; Dual K&N
Drive Train: RPS Carbon-Carbon Clutch;
Drive Train: Kormex LSD;
Drive Train: PST CFDS;
Suspension: TEIN Flex w/EDFC;
Brakes: StopTech ST40 brakes & 355x32MM AeroRotors® rotors (Front) SuperCar Engineering;
Brakes: StopTech ST22 brakes & 328x28MM AeroRotors® rotors (Rear) SuperCar Engineering;
Wheels: PIAA 18x9.5 FR-S w/45mm offset ;TOYO Proxes T1-R 18x275x35;
Gauges: Defi-Link (EGT, Water Temp, Fuel Pres, Oil Pres, Oil Temp, Boost and Display);
Gauges: 2 AEM WB02 (Left & Right Bank);
Cooling: Fluidyne DB-30816 Front Mount Oil cooler (currently deinstalled);
Cooling: 3SX Dual-Pass Radiator w/Flex-lite fans;
Cooling: Waterless NPG+
HydeDW is online now   Reply With Quote
Old 08-27-2005, 11:40 AM   #50 (permalink)
JOJO's Avatar
Drives: mitsu vr4
JOJO is an unknown quantity at this point
RAYS Gram Lights 57s-pro 18x9.0 5x114.3 +42 offset
i dont know if some one post this one already but here it is anyway..
JOJO is offline   Reply With Quote
