Old 03-19-2005, 02:52 AM   #31 (permalink)
3S Obsessed
HydeDW's Avatar
Drives: 97 VR4
Trader Rating: (11)
HydeDW Level 2HydeDW Level 2HydeDW Level 2HydeDW Level 2HydeDW Level 2
Default Re: WHEEL LIST - Rims that WILL fit a TT/VR-4
http://www.importmodifications.com/wheelweights.html
Specs I found that may be of interest to some here
Dan (3SI #37)
Pearl White 1997 VR4 (117K 4/2007)
Engine: 13T Turbos - Rob Beck engineered
Engine: AEM EMS; GM 3.0 MAP, GM IAT, GM EBC, RC550's
Intake: Dejon Hardpipes; Dual K&N
Drive Train: RPS Carbon-Carbon Clutch;
Drive Train: Kormex LSD;
Drive Train: PST CFDS;
Suspension: TEIN Flex w/EDFC;
Brakes: StopTech ST40 brakes & 355x32MM AeroRotors® rotors (Front) SuperCar Engineering;
Brakes: StopTech ST22 brakes & 328x28MM AeroRotors® rotors (Rear) SuperCar Engineering;
Wheels: PIAA 18x9.5 FR-S w/45mm offset ;TOYO Proxes T1-R 18x275x35;
Gauges: Defi-Link (EGT, Water Temp, Fuel Pres, Oil Pres, Oil Temp, Boost and Display);
Gauges: 2 AEM WB02 (Left & Right Bank);
Cooling: Fluidyne DB-30816 Front Mount Oil cooler (currently deinstalled);
Cooling: 3SX Dual-Pass Radiator w/Flex-lite fans;
Cooling: Waterless NPG+
HydeDW is online now   Reply With Quote
Old 03-22-2005, 05:10 PM   #32 (permalink)
Semper Gumby
teufelsunde's Avatar
Drives: '95 3000GT VR-4
teufelsunde is an unknown quantity at this point
Thank you!
Kevin
P.S. Bump.
"Do you serve a purpose or purposefully serve?"
teufelsunde is offline   Reply With Quote
Old 05-02-2005, 10:16 AM   #33 (permalink)
3SNY President
ifithas2be's Avatar
Drives: 91 VR4
ifithas2be is an unknown quantity at this point
I dont have enough things on my mind and I dont have enough things to worry about. Im going to start making a new 3S VR-4 / TT wheel site. The only catch is I want 1 or 2 people to help me. The only thing I want to do is design & host the information. What I would like others to do is the research and sorting of data collected. I need AIM names for anyone who wants the work, any takers?
3000GT STEALTH CLUB of NEW YORK
ifithas2be is offline   Reply With Quote
Old 05-08-2005, 11:34 PM   #34 (permalink)
Numure is an unknown quantity at this point
wat are some cheap rims and tires i can buy for a '93 twin turbo stealth ... i want something flashy yet light weight .. just got her today andi want her looking sharp for pictures v... a recommended website would help too where i can buy them from ... thanks!!!
Numure is offline   Reply With Quote
Old 05-18-2005, 09:10 PM   #35 (permalink)
Drives: 92 Stealth tt
stealthyinpa is an unknown quantity at this point
Anyone know if ADR Cypher wheels fit? (18x8.5 and 18x9.5)? Thanks
stealthyinpa is offline   Reply With Quote
Old 06-05-2005, 08:17 PM   #36 (permalink)
Trifler's Avatar
Drives: '97 3000GT VR-4
Trifler is an unknown quantity at this point
I'm guessing the list doesn't include wheels that fit with a spacer. I have 18" Volk Racing TE-37s. They are hubcentric. I need a 3mm spacer on the front wheels because I have 275/35 tires. If you use narrower tires they would probably fit without the spacers. 3mm is really small. These wheels are only 16 pounds according to Volk Racing (not including tire weight) even though they're 18" wheels. They're the lightest I was able to find anywhere without having some custom made.
Volk Racing 18x9.5" LE-37 Wheels, Yokohama 275/35 dB Tires, JIC Coil-Over Struts/Shocks, Supercar Engineering Tender Springs, PST Carbon-Fiber Driveshaft, K&N FIPK Air Intake, DN Stainless Air Intake Pipes, Ultimate Performance Cold Air Box, TM Rear O2 Sensor Housing Eliminator w/ceramic coating from Swain Tech, Pit Road M 80mm Twin Flex Downpipe w/ceramic coating from Swain Tech, Random Technology 3" Ultra-High-Flow Catalytic Converter from 3SX Performance, Custom 3" Cat-Back Exhaust, 2 Flowmaster Universal High-Flow Mufflers, GReddy Type-S Blow-Off Valve, Supercar Engineering 14.5" Front Brake Kit with 6-piston AP Racing Calipers, Carbotech Bobcat Brake Pads, 3SX Silicone coated SS Braided Brake Lines, Saner Front Sway Bar, Quickor Rear Sway Bar, TurboXS Manual Boost Controller
Trifler is offline   Reply With Quote
Old 06-05-2005, 08:45 PM   #37 (permalink)
I'm a Troll
I am Me N u r U's Avatar
Drives: a turd
Trader Rating: (20)
I am Me N u r U is an unknown quantity at this point
this list is specifically for rims that will fit WITHOUT a spacer
I am Me N u r U is offline   Reply With Quote
Old 06-07-2005, 01:05 PM   #38 (permalink)
9B WEAKSAUCE since 2001
undertaker's Avatar
Trader Rating: (13)
undertaker is an unknown quantity at this point
so Volk TE37's will fit a second gen in 18x9 w/ 40mm offset???
They are pretty much the lightest (other than buddy club) that will fit the tires I bought.
undertaker is offline   Reply With Quote
Old 06-07-2005, 04:38 PM   #39 (permalink)
Trifler's Avatar
You can have a local shop like Discount Tire or whoever you want to use order one wheel and test fit it when it arrives on both of the front wheels. If it fits, then they'll order the other three. If it doesn't fit, they'll often return the wheel for you at no charge. Some will charge the cost of shipping the one wheel, but that's not much.
Old 06-07-2005, 04:49 PM   #40 (permalink)
undertaker's Avatar
Trader Rating: (13)
Thats hard to do when my car is on jackstands in my garage...unless they'd let me take the wheel home with me. I am going to end up buying offline anyhow because its ALWAYS cheaper.
