3SI member name: SkortchGT
Car: 92 VR4
Wheel brand: 5zigen FN01R-C
Wheel size: 18x8.5
Offset: +30
Front Brakes: Upgraded to OEM 2g's all around
Suspension: Tein FLEX Coilovers
Notes: Fits like a glove, room to grow for big brakes, front wheels stick out a tiny tiny bit.
1992 3000GT VR4
--Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/f116/car-finally-running-after-year-being-down-372579/
--First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, cat back & CFDS, time for another dyno run soon)
--Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, PST 1pc CFDS, Borla Catback, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, engine dress up kit, Bigtyla ground wire kit, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset.
--Waiting for me to install: ARC2 w/ 92mm MAS
--Daily Driver: 2000 Malibu, 6cyl, auto
Notes: About 2 mm clearance to caliper - see pic. Plenty of strut clearance - enough for 275 tires (next time). Tires stick out about 3/4" more than stock, but look OK.
Reason: added photos & Teins now installed.
OEM G35 Coupe 19" wheels should fit from what I'm reading..
8.0" +33MM up front and 8.5" +30MM rear. The outer diameter of the tires is almost identical so the different sizes shouldn't matter and 19" wheels weighing in at 19lbs each OH yeah they'll be sweet!
How about removing this post until you can confirm without a doubt that they fit? This isn't the thread for "From what I've read, I THINK these should fit".
Max
1994 3000GT VR-4. Hobbies... what are hobbies? Oh, those things people do when they're NOT working on their cars?
3SI member name: marcmayer
Car: 95 Spyder VR4
Wheel brand: Nissan - 350z Anniversary Edition '05 -'08 cars
Wheel size: 18x8.5
Offset: +33
Front Brakes: Stock (powdercoated by Terry at Maximal)
Suspension: Stock - ECS
Notes: I used 2 sets of rears (18x8.5 - 33 offset) - stock 350z rims are staggared with front 18x8 (30 offset) and I don't know if those will clear. Minor modification to wheel required - hub bore needs to be increased just slightly from 66.1mm (Nissan std) to 67.1mm (Mitsu std).
Black '95 Spyder VR4
'99 Front End/Rear Garnish
Chrome 18x8.5" 350Z wheels with Hella TPMS
DBA 4000 Slotted Rotors - HPS Pads - SS lines
Powder Coated Calipers
Interior Rearview Mirror with Temp/Compass/HomeLink
Keep them coming guys. I havent forgotten about making a database of wheel specs for our cars. Just got hammered with alot of other website work, but i'm keeping things organized.
17x7 Kyowa Racing KR206 Flat Black with Red Stripe lip. = 5x114.3
Will these fit a 1992 Vr4? I'm trying to find some replacement rims with out replacing the tires.
