Old 04-13-2008, 09:39 PM   #1 (permalink)
Paid Member
3kgtSL91's Avatar
Drives: 92 VR-4
3kgtSL91 Level 13kgtSL91 Level 1
Question What width/offset I should go with?
Hello all and thanx for watching. Basically, I am getting widebody rear and front fenders for my 92 vr-4 and want to stick with 19" rims. What offset and what width should I go with so I can put wider tires on my rims, anybody know?
I was thinking going with Piaa Super Rozza rim which is 19x9.5 +42, will that work? This is the list of all offsets and width they offer: http://www.piaa.com/Wheels/img/super_rozza_info.gif
Thanx in advance
1997 Red MMC 3000GT
1992 Dark Grey MMC 3000GT VR-4
2009 Blue Nissan Murano SL
2008 Black Honda Civic EX-L
2005 Red Ford Mustang GT
2006 Black Subaru Impreza STi - SOLD
1991 Blue MMC 3000GT SL - SOLD
07 MB S65 & 07 MB G55 - Overseas
3kgtSL91 is offline   Reply With Quote
Old 04-14-2008, 05:09 AM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (63)
Default Re: What width/offset I should go with?
The +42mm offset will tuck it into your fender more than you'd want with widebody fenders, I would think. The 19x10 with +25mm offset would stick out quite a bit, and you could run 19x9 with +25mm offset in the front in order to clear the struts. Then you'd need to find two identical O.D. tire sizes - 265/35/18 and 275/35/18 would be 1.1% different.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts p.s. buy my stuff
Old 04-14-2008, 05:49 AM   #3 (permalink)
Paid Member
3kgtSL91's Avatar
Drives: 92 VR-4
sorry for the stupid question but how do you calculate all that?
Old 04-14-2008, 05:53 AM   #4 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (63)
Tire size calculator
With the offset, I just know that my rims are +43mm and they don't stick out from the fender at all. MY gf has +24mm offset and they stick out from her fender maybe a quarter inch.
Old 04-14-2008, 05:56 AM   #5 (permalink)
Paid Member
3kgtSL91's Avatar
Drives: 92 VR-4
thanx for the link but can I go with wider tire in the rear? I heard that it is not recommended with awd cars...
Old 04-14-2008, 06:01 AM   #6 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (63)
You can use varying widths as long as the rotating diameter is equal or very close. I admit 1.1% will be pushing it, and you could run 265/35/18 on all 4 to be safe if you wanted. I assumed with a widebody that you wanted thicker tires on the back -- and it would be close (but I admit possible) if you wanted to run 275/35/18 tires on the front.
Old 04-14-2008, 06:11 AM   #7 (permalink)
Paid Member
3kgtSL91's Avatar
Drives: 92 VR-4
what about 265/30-19 in front and 275/30-19 in the back. It looks like the difference is .9
Old 04-14-2008, 06:19 AM   #8 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (63)
That could work. I am not sure how the roads are around you, but around here there are far too many potholes for a 30 sidewall ... although with those widths a 30 might be ok. It's not a common size tire -- probably going to be pretty expensive.
Old 04-15-2008, 10:55 PM   #9 (permalink)
Drives: vr-4, 5.0, durango
mrdillyo is an unknown quantity at this point
just one thing to remember the side wall number is a percent of the with i.e. if you have a 275-30-19 the side wall would be 30% of 275 =82.5 mm. ;265= 79.5 so try to get your height as close as possible. if you could fit 295-25=73.75 ;and 245-30=73.5 it would be very close but i have no clue how those fenders fit. take your time and if you can find locally you can check fitment but logically thinking i don't think 3mm's are going to do much more then improper tire inflation
mrdillyo is offline   Reply With Quote
