#1 (permalink) |
If all 4 tires on a vr4 AWD are all different PSI, for example, 51 PSI max on Falken tires is what i have, and if all 4 tires were let say 42 50 40 45 PSI, this could hurt the transfer case right, i hear that the psi has to be perfect, and the tires have to be the exact size to
#2 (permalink) |
Damage Control
You should NOT run your tires at max psi.
They should be right around 32 psi front and 35 psi rear. The difference of 3 psi is not going to greatly change the overall cicumference.
Kbizzle [11:25 P.M.]: this is most displeasing |
#4 (permalink) |
Sexual Tyranosaurus
wrong.
if your tires are rated at 51 psi, keep around 45 in them. 45 front and 41 rear would be a comfortable ride. 35 psi in them you would lose mileage and tire life I dont think that small a difference would cause any adverse effects in your drivetrain
3sx Dowpipe Gutted Cat 2.5 Inch Magnaflow
Fidanza Cam Gears Spec Stage 2 Clutch Fidanza Flywheel IPO's MSD Wires FIPK 3sx Poly Motor Mounts 93 Vr-4 Chromies Adco Rear Sway Bar TEC Rear Strut bar 255 Dunlop Direzza's 1st Gen TT Front Brakes Hawk HP Plus Pads Carbing Replica Front Strut Bar (fabb'd up by yours truly) Adjustable Lower Control Arms Ground Kit FN01R-C's As05 Hoosiers (Track use) <-- Tein Flex |
