Old 06-23-2008, 08:20 PM   #1 (permalink)
BLACK STEATH TT!
Drives: 93 Stealth RT TT
AceJas Negative 1
Default Tien S and 18 Inch Tires
Is it ok to put the type s springs with 18 inch Tires?
Also how hard is it to replace the springs?
93 Stealth RT TT Black with Black Leather. 575 Deft CF hood,K/n Cold air filter,Hks SSQ blow off valve,Aluminum cold air box mated to CF hood,3sx Poly engine Mnts,99 lifters,egr block off,vacume reduction,Chrome ypipe,Tein S spings,3sx stealth cut-thru spark cover,3sx Aluminum shifter trim,3sx Aluminum Twin Turbo pedal covers,Aluminum Stealth Door sills,CF shifter+boot+ebrake,CF ebrake handle cover,3sx CF Full Dash kit,Aluminum Oil cap.Stage 3 clutch, New flywheel,boost controller, boost guage, Gutted precats, Downpipe, 3' Strait Exhaust, 18 inch Aluminum rims and tires.Stage I complete. Jumped time+bent Intake vales
AceJas is offline   Reply With Quote
Old 06-23-2008, 10:09 PM   #2 (permalink)
Paid Member
outkastvr4's Avatar
Drives: 92 vr-4, 87 yota
Trader Rating: (7)
outkastvr4 is an unknown quantity at this point
Default Re: Tien S and 18 Inch Tires
i have 18s and tein s-tech springs and no problems
1992 3000GT VR-4- CUSTOM to4e single turbo kit, full 3in exhaust with 2 1/2 outlets, ported intake,550s,safc2,GM MAFT,4in FMIC, and much more to be bought
1987 Toyota turbo pickup-SOLD
1995 Nissan 240sx-bone stock project car
outkastvr4 is offline   Reply With Quote
Old 06-23-2008, 10:37 PM   #3 (permalink)
getting there
nawz8r's Avatar
Drives: '91TT '02Avalanche
Trader Rating: (8)
nawz8r Level 3nawz8r Level 3nawz8r Level 3nawz8r Level 3
Mine are 19's with no problems. The diameter of the wheel/tire combination is close to stock 17". The aspect (width) of the stock tire is 45, and the aspect of the 19" tire is 35, so bigger rim + shorter sidewall = smaller rim + taller sidewall. A 18" rim should take a tire with an aspect of 40, and you'll be fine. Springs drop half off the wheel gap with NO rubbing over bumps that I've found
1991 TT. K&N FIPK, DNP Y-pipe, '99 lifters, Hallman mbc, Greddy RS BOV, Tein S Techs, 3SX DP, H-flow cat, Moda MD1 19x8.5
nawz8r is offline   Reply With Quote
Old 06-27-2008, 08:19 AM   #4 (permalink)
ADiggidoyoF's Avatar
Drives: 92 RT/TT
ADiggidoyoF is an unknown quantity at this point
nawz8r,
Did you install yourself or have a shop do it? How much/hard was it? I plan on doing this same thing in the next month or two (tein s+18's)
91 Dodge Stealth ES - >>SOLD<<
92 Dodge Stealth R/T TT - Alive and kickin... hard: www.cardomain.com/id/diggidoyo
Current mods: ~ 18x9 Saleens ~ 265/35/18 Sumitomo HTRZ IIIs ~ Tein S.Techs ~ Deft's Venom Viper Bumper ~ Polished Intercooler Pipes ~ Cross-drilled/slotted rotors ~ HKS Intake ~ IPS 3" Catback w/ A'PEXi N-1 Canisters ~ A'PEXi AVC-R Boost Controller ~ Turbo XS RFL BOV ~ 3sx Plug/Wire Covers ~ NGK wires/plugs ~ 20% tint ~ Full Audio System w/custom box ~ Shark radio antenna ~
ADiggidoyoF is offline   Reply With Quote
Old 06-27-2008, 08:35 AM   #5 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (65)
Originally Posted by ADiggidoyoF View Post
nawz8r,
As long as you have a spring compressor it will be easy.
Take the struts off, compress the springs, unscrew the top hats, replace the springs, put them back together, and back on the car.
Then of course you will need an alignment.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 06-27-2008, 09:33 AM   #6 (permalink)
Venom Speed Shop
Venom13132's Avatar
Drives: Small Car Big Engine
Trader Rating: (101)
Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7Venom13132 Level 7
It will take me just a few hours to do your springs on your car. I just have to rent a spring compressor from advance auto
Venom13132 is online now   Reply With Quote
Old 06-27-2008, 11:25 PM   #7 (permalink)
getting there
nawz8r's Avatar
Trader Rating: (8)
nawz8r,
Installed them myself. There's an Intrax Spring install on Stealth 316.com which is the same. You will probably need adjustable upper control arms for the rear since the stock "fixed" length arms may be too short for camber adjustment after install, however some claim they didn't need them. Mark the eccentric bolt markings on the front struts before removing, and install the same marks aligned. Then, as lawdogg posts, get an alignment. One other thing, the bearing on the top strut mount for the front struts should be in good shape as the strut pivots as the steering is turned - replace the bearing if needed.
