#1 (permalink) | |
Single Club
I was reading about Saner Sway bars and how they improved the handling of the car. Helped with the common under steer issue with the 3KGT. Are their other options out their? I have k-sports and rear adjustable control arms for improved handling. I'm just looking to make the car a little tighter and more responsive. I have already lighted the car I'm probably at 34xx lbs so any input would be great!
#2 (permalink) |
Praise RaptorJesus!
Based on how swaybars work, and the fact that you already have Ksports which are stiff, I wouldn't.
Swaybars and what they do |
#3 (permalink) |
That link is awesome! I always knew that they took away grip instead of add it. I never understood how a bar in the back could affect grip in the front lol.
So basically, if you want the car to handle more neutral but with less total grip then upgraded sways are great. And if you do upgrade them too much (too thick/stiff) then it has actually makes the situation worse because the outside wheel isn't getting a lot more grip but the inside wheel is losing more and more right? Again, GREAT link.
![]() 1994 3000GT SL - Old Daily Driver SOLD Custom Paint, Full Custom Exhaust, etc. 1993 VR4 with 150K miles - Daily Driver/Weekend Warrior/Sole Method of Transportation Go: eBay Tanabe Concept G Blue Replica TBE, Metal Evo DV, Maximals TC Bracket, PST Two Piece Steel/Aluminum Driveshaft Monitoring: Palm M100 with MMCD, STRI X-Line Boost Gauge Maintenance: 120K with oil pump and main/rod bearings, MSD 8.5MM wires, NGK Platinum plugs, Redline/Castrol Fluids, New ECU, Lowes Pressure Tester, New IAC/PVC/etc. Show: '99 Garnish, Alan's Snake Eyes, Stealthy Wiper Mod, 3SX Aluminum Pedals |
