Old 03-05-2008, 04:26 PM   #1 (permalink)
King Detail
ProwlerGT's Avatar
Drives: 95 3000GT Base DOHC
Trader Rating: (9)
ProwlerGT is an unknown quantity at this point
Question Slider bolt problems
I'm doing the painstaking job of removing all calipers to clean the sliding bolts and bores so that I can remove the wrong grease (used suspension grease) and apply the correct slider bolt grease instead. After I finished the 1st caliper at the front right I noticed the lil rubber piece at the end of 1 of the slider bolts is I guess widened too much to allow the bolt to slide in and out easily. How easily should this bolt slide in and out of this bore? I must apply FULL FORCE to even budge it 1mm downward into the bore. Do ya'll think the suspension grease swelled this rubber piece over time? I have not driven it but 5-10 TEST miles and noticed my brakes were sticking/heating up.
Do I even need this rubber piece at the end? What would happen if I removed it completely? It seems the brakes would slide a lot easier without this piece even being in there to begin with. Pictures attached:
INFO LINKS FOR EVERYONE:
 ProwlerGT's Revival Thread | My Service Log | IAC | SENSORS | Hesitation Tracking List | NO3S.com
Lata,
ProwlerGT
"Those who know me, know my real name and more importantly how to say it right."
ThinkAbtIt on AIM | searcherrr on Yahoo IM | Email in profile
ProwlerGT is offline   Reply With Quote
Old 03-06-2008, 10:35 AM   #2 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (9)
Question Re: Slider bolt problems
Is why I need this bushing because it makes a suction which pushes the caliper back apart after the brakes are applied?
Old 03-06-2008, 01:22 PM   #3 (permalink)
Anti-Rice
tabasco122's Avatar
Drives: '08 Mitsu Lancer GTS
tabasco122 is an unknown quantity at this point
Default Re: Slider bolt problems
i dont see why they would go through the trouble of engineering that bolt with room for the rubber thing, along with the process of making the rubber and putting it on the bolt during assembly if it wasnt necessary. my $0.02
Originally Posted by beastly-srt View Post
Originally Posted by tabasco122 View Post
is it sad that im disappointed there isnt anyone that stupid out there? it made me feel good about myself...
don worry son, you always got me dog...
if you eva feelin down or blue, just close you eyes, and ill be there acting like a fool, talkin about shit i know nothin about and pretendin to be a gangsta even tho my mom still does my laundry... piece out.
-respecT
tabasco122 is offline   Reply With Quote
Old 03-06-2008, 05:17 PM   #4 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (9)
Hey Ryan. I agree. It just really bothers me that I can't get it to go in AT ALL and so if I did manage to get it in there it would move very very sluggishly if at all. I guess I just have to get it all lubed up well and try again at it.
Old 03-06-2008, 08:09 PM   #5 (permalink)
Anti-Rice
tabasco122's Avatar
Old 03-06-2008, 08:14 PM   #6 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (9)
LOL - I hope that what I've bought is the KY equivalent for the slider bolts. lol - you ass.
Old 03-06-2008, 08:18 PM   #7 (permalink)
Anti-Rice
tabasco122's Avatar
Just a suggestion, lol. Since nobody else is helping you and i dont know much about brakes, i figured i would try to make you laugh...
Old 03-06-2008, 08:28 PM   #8 (permalink)
Stealth Like A Ninja
Darksurfr's Avatar
Drives: '91 Stealth TT
Trader Rating: (14)
Darksurfr is an unknown quantity at this point
I would say just make sure you have the slider bolt grease...i dont know if that green crap in the picture is the "old suspension grease" but you should definitely CAKE that slider bolt grease all around that bolt to the point where you know you cant put any more on. there should be an EXCESS of that stuff just all up inside that caliper body. other then that I don't know what else would be wrong.
ECG 2005 / Attended ECG 2006 / Attended
ECG 2007 / Attended ECG 2008 / Attended
NEG 2005 / Attended
NEG 2006 / Attended NEG 2007 / Attended
Member of 3SNJ
Darksurfr is offline   Reply With Quote
Old 03-06-2008, 09:49 PM   #9 (permalink)
sweet91
sweet91's Avatar
Drives: 91' VR4
sweet91 is an unknown quantity at this point
I always use lithium grease. ( Don't know if I spelled that right ) Seems to do the trick.
sweet91 is offline   Reply With Quote
Old 03-07-2008, 02:28 AM   #10 (permalink)
htlaets1's Avatar
htlaets1 is an unknown quantity at this point
I second the lithium greese, alway worked good for me. maybee double check make sure the grommet is seated correctly in the slidder's bore, but I think lube is the key the entire slidder must be lubed, install, then wipe off excess
htlaets1 is offline   Reply With Quote
