Old 10-20-2009, 12:54 AM   #1 (permalink)
Philisdiller's Avatar
Philisdiller is an unknown quantity at this point
Default replacing struts with ECS or not?
Hello all, this is my first real post on this forum. I just purchased a 1991 3000gt SL yesterday for 1000 dollars. It's been sitting for probably two years.
I'm pretty sure that the right front strut is completely shot because it violently shakes the whole car when going over bumps, rough road, etc.
I'm wondering whether to replace both struts with OEM ECS struts, get the KYB replacement struts without ECS, or just get some more performance struts/shocks. what I'm trying to ask is, how big of a difference does ECS make and how big of a difference do performance struts make.
going to be mostly road driven, but I have a heavy foot and like to have my fun :P
Thank You
Philis diller
Philisdiller is offline   Reply With Quote
Old 10-21-2009, 12:15 AM   #2 (permalink)
ReD_95's Avatar
ReD_95 is an unknown quantity at this point
Default Re: replacing struts with ECS or not?
i would like to ask if anyone knows which struts am i suppose to put on my 95 3s, either the ecs or non ecs? thanks
ReD_95 is offline   Reply With Quote
Old 10-21-2009, 12:45 AM   #3 (permalink)
3Sfever's Avatar
Drives: '91 Stealth TT
3Sfever is an unknown quantity at this point
Originally Posted by Philisdiller View Post
. . . .what I'm trying to ask is, how big of a difference does ECS make and how big of a difference do performance struts make.
I can not compare to any alternatives, but I like the ECS struts. . . I recently had to replace mine and went with these again. I like option to change from softer for most driving, or firm for the track/spirited-driving.
ECS struts will have a wiring harness attached to the top post. (hopefully that answers your question, I am not familiar with '95)
-Ron
'91 Stealth TT
purchased Aug 2004
3Sfever is offline   Reply With Quote
Old 10-22-2009, 02:19 AM   #4 (permalink)
Thanks a lot 3sfever!
hey just wondering where did you end up getting yours?
I found some on 3sx for 164 per strut. I could get a pair of used struts for about 100 on ebay but i'll probably end up getting them new
Old 10-22-2009, 02:31 AM   #5 (permalink)
Mitsubishi Junkie
Joel_CA's Avatar
Drives: 2 Pearly Whites
Trader Rating: (7)
Joel_CA Level 1Joel_CA Level 1
Cherryhillmitsubishi.com (click on parts) sells each strut for around $130 each. I also personally enjoy the ability to switch back and forth between Sport and Tour. If you're going as far as replacing your struts- now is the perfect time to lower your car with a set of springs. Good luck!
JJ
1992 3000GT VR4 (tastefully modified) & 1996 STEALTH RT/TT #47 (restoration work in progress)
Joel_CA is offline   Reply With Quote
Old 10-22-2009, 03:56 AM   #6 (permalink)
Thanks man. I'll look into that.
Old 10-22-2009, 01:31 PM   #7 (permalink)
3Sfever's Avatar
JJ
^^^ same place I got mine.
Old 10-22-2009, 02:05 PM   #8 (permalink)
Yeah that seems like the best deal I've seen so far. I'll definitely be picking
mine up from there.
I was looking into lowering springs and I found the intrax springs. Those seem
pretty good. I'll do a search right now on them but just wondering if theres
anything better for the price or if those are good.
Old 10-22-2009, 11:57 PM   #9 (permalink)
3Sfever's Avatar
I remember it was a close decision between Cherry Hill and IPS IPS Motorsports. . . . I think I went with Cherry Hill because there was some other OEM stuff I needed, that IPS did not list.
Struts = $144 at IPS, shipped. This might be similar total cost to Cherry Hill.
