#21 (permalink) | ||||
King Detail
Hey, I cleaned up a bit around the cv bracket and its intact, but I did find that it looks like something impacted it at one spot. Take a look - Cause for concern? Would that have been a very FORCEFUL impact or does it not take much to dent it there?
![]() I guess on the former note I'll just lower the car and when its down on the ground I'll ensure that the top ball joint nuts are still tight.
#22 (permalink) |
King Detail
Do I have the setup for removing the ball joint wrong? I am in the middle of it now ( HELP ! ):
Is this C clamp setup correct? I ask because I'm encountering dead stop force. Should I continue with it how it is setup? ![]() Here's the whole setup for how I'm situated to get to the ball joint with jack stands at lowest level. ![]() Here's what the ball joint looks like with the dust over removed which reveals the circlip. I found you can use a snap ring tool by itself without an attachment end and it just barely spreads the clip out enough to pull it directly upwards as you are using the tool. ![]() |
#23 (permalink) |
Certified Car Nut
From what i can tell, you have it set up right. As long as the spacer on the bottom is large enough in diameter, the joint should press out and down through the bottom spacer. I never had much luck pushing down on the shaft like your pic shows, but it looks like you have a better setup than me. If that doesn't work, try using a different spacer on top...one that will push down on the top circumference of the ball joint base instead of pushing down on the shaft.
Jeff W.
Red '92 VR4 214,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, 1/4 mile at a time, the rest was easy ![]() Big 16G Turbos w/IPS headers and pre-cat eliminators, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, DR Fuel Pump Hotwire Kit, South Bend FE/SS Stage 5 clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, PowerStop/Stillin rotors, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi wheels, 2-tone all-leather Interior. |
#24 (permalink) | ||
Mitsubishi Junkie
The cheaper route would be to replace the axle though i feel an OEM unit is likely stronger. FYI, you don't need to break the BJ free when replacing the axle assembly. Just remove 2 upper strut mount bolts and you'll be able to swing the knuckle around to remove it - just be sure you mark the position/rotation of the bolts so as not to affect your camber adjustment. As what Jeff said- reinsert the BJ shaft into the knuckle base and tighten the nut. That is all that is needed to seat the tapered shaft. Adding the weight of the car won't really do much but compress the springs. Also- if you've loosened the lower control arm mounting bolts so that you can pivot the arm up and down freely to press out the BJ- be sure you retighten them with the suspension AT RIDE HEIGHT when you're all done. That means- finish the job and reassemble everything (minus the wheels), put your floor jack under the lower control arm- and jack it up so that the suspension is sitting at normal ride height, THEN tighten the lower control arm mounting bolts. The idea is to center the lower control arm bushings AT RIDE HEIGHT before clamping them down. If you tighten it and clamp the lower control arm bushing while the the suspension is fully extended, lowering the car back to ride height will put some "preloaded" twisting onto the bushing which will only cause the bushing to wear faster. Driving it in that condition will only make things worse as the suspension compresses over bumps further twisting the bushing further than it was intended to ever twist. Good Luck! J
![]() 1992 3000GT VR4 (tastefully modified) & 1996 STEALTH RT/TT #47 (restoration work in progress) |
#25 (permalink) | |
King Detail
Thanks for the notes about the lower control arm mount bolts. It is very good stuff to know, but I purposely have NOT loosened them. I'd rather not have a long road back to getting all this reassembled so I only take off what I need after I've devised ways to get to only what I want. I guess thats pretty typical though aye. As far as the CV boot goes - check this out: Think those eBayer's are any good? With that said, you really think its just leaking from the rubber boot? I mean couldn't I clean it up well and rtv the seal edge? To get the boot off I'd have to go get yet another tool (32mm socket to get the big ass bolt off the end). This to me has turned out to be the best thread I know of for replacing our ball joints ! |
#26 (permalink) |
King Detail
BTW - I ended up doing the removal just how I have it pictured pushing down on the shaft. It required near perfect alignment of the tools, but it came out and there wasn't even any POP. It just came loose.
INSTALLATION SUCCESS !!!!!! Below are some pictures of installation and post-installation stuff. A very important thing to note since I know many of you get the same ball joints and rent from AutoZone as well is that using the method I did in the pictures below for installation It left a few millimeters of space between the rim of the ball joint and the control arm mount hole underneath. To make sure I was't seeing a shadow or anything I stuck a Stanley needle picker in there. The BJ was flush on one side, but off on the other and this was because I'd reached my press limit with the tool. The top bolt of the ball joint ended up touching the base of the huge screw plunger thingy so this meant all I was doing was going no where. Still with about 5 - 7mm left to close in on I remembered ya'll suggesting using a big socket earlier, but in a different way than I was trying to do here. Shown in the photos below you'll see the socket is "big open end for bolts" on the downside. This allowed for the ball joint bolt to go upwards just a few hairs more in order for me to make the ball joint rim flush with the lower control arm underneath. Comparison of Old vs New - Despite the dust cover being open and broken I really found both ball joints to have nearly the same break away resistance. I just used my hands though, so I dunno. It sure is tempting to just clean the damn thing up with some spray oil and put it back in with new covers and lube. ![]() Ball joint installation - The winning combination of tools. Using the C-clamp going upwards listing the parts in between it we have the bottom platter with an end that fits well into the bottom of the c-clamp, ball joint base, control arm, medium sized dual open ended cup or pipe thingy, platter which fits the bj bolt pretty well, and then the savior 3/4" or 15mm socket which allows for the bolt to come up just a tad more to mount the bj flush with the arm bottom. Once you can't turn it anymore, give it one good half or full turn and you are done. Inspect below the arm to see that the ball joint lip is flush with the arm hole mount point. Suggest having an extra hydraulic jack to hold the hub/knuckle to the side (rear) of the arm and 2 qty small length 4x4's would be a HUGE help as well to rest the arm on eliminating you having to fight the play in the arm while doing this. Believe me, your back will thank you. ![]() Another view. ![]() |
#27 (permalink) | |
Mitsubishi Junkie
J |
#28 (permalink) |
Certified Car Nut
Good job! and great pics. So it's fixed, it's fixed right, you learned something, and you didn't have to pay a shop to do the work!
Just for reference, the local tire store wanted to charge me over $450 for each control arm plus $300 labor to install them. All this just to replace the balljoints like you just did for under $100. |
#29 (permalink) |
King Detail
Yeah I did it and it was just as much you guy's doing as it was mine. Couldn't have done it without the info that is either missing or vague in the manual and while there are tons of other ball joint pages on the web none of them were specific to our cars, the low clearance, and the infamous dealer listed "can't push these ball joints out of these" lower control arms. Paaaalease. It was great learning something new and seeing (instead of reading) how the suspension pivots using all those joints. I've never really known fully till now.
YEAH THE PRICE ! ISN'T THAT AMAZING ! That saved all kinds of $$$ JACK $$$ ! Now for me to just go do the other damn side which I'm hoping will go a lot faster now that I'm not afraid of breaking something. lol |
#30 (permalink) |
King Detail
PICKLE FORK (ball joint separator) - One other note I forgot to mention which will prevent you from smacking yourself and the car up is when you place the fork between the knuckle and the arm to wedge the ball joint from the knuckle be sure you have the fork flipped on the side which has the fork handle angled downward and not straight out level with the top surface of the arm (same principle here as with wrenches with an angled end). I had done it with the fork handle pointing straight out and it was hard to not hit the car (hammering from the front of the car towards the back) while hammering.
