Old 07-27-2008, 02:49 PM   #1 (permalink)
Drives: 1997 3000gt vr4
drobvr4 is an unknown quantity at this point
Default rattle from rear strut are
when ever i hit a a bump, whether it be big or small, i hear a rattle from the rear of the car coming from the strut areas like something is loose. This happened when i got new bilstein struts and eibach spings. I emptied out the trunk area and it still made the noise. Anyone ever have this problem?
drobvr4 is offline   Reply With Quote
Old 07-27-2008, 07:08 PM   #2 (permalink)
Forum user
Monster Stealth's Avatar
Drives: 93 VR4 & 99 A4 1.8T
Trader Rating: (25)
Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7
Default Re: rattle from rear strut are
Did you replace the strut mounts when you installed your bilstiens? Or at least inspect them? You may also want to look at your swaybar endlinks.
9b 13.2 w/ 93 Pump
Originally Posted by Jeremy Clarkson
I am sorry officer, my foot must have slipped off the clutch!
Monster Stealth is offline   Reply With Quote
Old 07-27-2008, 09:17 PM   #3 (permalink)
95teetee's Avatar
Drives: 95 Stealth RT/TT
95teetee Level 795teetee Level 795teetee Level 795teetee Level 795teetee Level 795teetee Level 795teetee Level 795teetee Level 795teetee Level 795teetee Level 795teetee Level 7
could be the coils of the eibachs hitting each other...
95teetee is offline   Reply With Quote
Old 07-28-2008, 10:36 AM   #4 (permalink)
'96 VR4
tachyon_ftl's Avatar
Drives: It's spos'd to move?
Trader Rating: (12)
tachyon_ftl Level 4tachyon_ftl Level 4tachyon_ftl Level 4tachyon_ftl Level 4tachyon_ftl Level 4
Are the Eibachs sized for 1996+ ? Our stock spring diameter is 1/2 inch smaller than the 1991 - 1995 cars. If the Eibachs are sized for 91 - 95, they won't match up correctly to 96+ spring perches and could definitely be rattling around.
tachyon_ftl is offline   Reply With Quote
Old 07-28-2008, 11:50 AM   #5 (permalink)
3Sfever's Avatar
Drives: '91 Stealth TT
3Sfever level 63Sfever level 63Sfever level 63Sfever level 63Sfever level 63Sfever level 6
^^^ I agree.
I think the Eibachs are notorious for that. The coils on the ends of springs are very closely spaced. It does not take much to bang them together. My Stealth rattles when going over uneven railroad tracks etc.
IIRC I read somewhere that Eibach would send out some "hose" that could be slipped over the coils to cushion the contact area. I keep saying I am going to look into that, but never seem to get around to it.
-Ron
'91 Stealth TT
purchased Aug 2004
3Sfever is offline   Reply With Quote
