need quick help with 91 sl addco rear sway bar install - 3000GT/Stealth International Message Center
Old 02-26-2013, 07:05 PM   #1 (permalink)
seawaver is an unknown quantity at this point
Feedback Score: 0 reviews
Default need quick help with 91 sl addco rear sway bar install
Let me start by saying that this is my first post on 3si but have used the website plenty for improvements to the car. I purchased the addco rear sway bar and am now installing it. basically I have both end links connected and they are pulled inward by the sway bar. also when I line up the sway bar for the bushings it is about an inch too far forward. I have no other aftermarket suspension parts except for the rear end links which are identical to the old ones. i have tried flipping the bar every which way but it just seems like its too short. Please help
seawaver is offline   Reply With Quote
Old 02-26-2013, 11:36 PM   #2 (permalink)
Default Re: need quick help with 91 sl addco rear sway bar install
Anyone?
Old 03-07-2013, 08:07 AM   #3 (permalink)
Old 03-07-2013, 11:30 AM   #4 (permalink)
Drunk as a lord
Forest Gump's Avatar
Drives: 1995 Stealth TT
Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2Forest Gump Level 2
Feedback Score: 100 reviews
I think I read someone say the car needs the rear suspension compressed to get that thing installed. Put some weight on the wheels.
Forest Gump is offline   Reply With Quote
Old 03-07-2013, 08:43 PM   #5 (permalink)
I tried it that way the first time but it didn't work. I even tried putting extra weight in the trunk and I tried jacking by the frame. every which way it seems like they made the bends in the wrong place with made the arms longer but the overall length shorter. I have seen some others had a problem like this but no solution ever came from it. I contacted addco about a month ago with no response
