#23 (permalink) | |
Cant get there from here!
BTW_ That air you have trapped may be in the ABS unit itself, and there may be special instructions somewhere about actuating the pump to get that air out. Sorry I dont have specifics, since I dont have it on my car to mess around with it. -SP
![]() One of 789 |
#25 (permalink) |
Thought of another idea I use on motorcycles-
Push the pistons back in after bleeding. This can force air bubbles back into the master cylinder where they can dissapate, while they sometimes can get "stuck" when pushing fluid through the normal direction. -SP |
#27 (permalink) | |
modding addicted
The other reason the order seems odd is because it is a dual circuit system. So the circuit with the furthest lines is bled first, then the circuit with the closest lines is bled last.
#28 (permalink) |
Damage Control
The ABS sensors are in the knuckle and wont be affected by pressing the pistons back in. ABS doesnt even work unless the car is moving over 15 mph anyway.
Kbizzle [11:25 P.M.]: this is most displeasing |
