Old 03-27-2008, 08:22 PM   #1 (permalink)
Helder 3k
Drives: 93 3000gt base
kyleh18 is an unknown quantity at this point
Default Lowering an N/A
I've been researching on lowering my car. I hear the tein s. springs are a good choice for the VR4's.
Are there different springs you would recomend for an N/A?
and also is all i would need to lower the car springs? or are the struts smart to replace as well?
Also is this a very hard instalation process? I've helped my buddy lifting his jeep, so i have some knowledge of this... but pretty much an amiture when it comes to this.
you input is well appriaciated thanks a lot!!
I'm sorry if there is already a thread like this. I looked and found many on TT'S, but not a whole lot on n/a. please add link for thread if this is already out there. thanks
kyleh18 is offline   Reply With Quote
Old 03-28-2008, 05:24 AM   #2 (permalink)
Born In Italy
italiano3kgt's Avatar
Drives: 1993 3000gt vr4
italiano3kgt is an unknown quantity at this point
Default Re: Lowering an N/A
you cannot use tien s tech springs, yes they will fit but they are not ment for an n/a.. you need to look at eibach springs, they are the only ones around that still make them for the n/a... it took me 30 min. to lower my front.. you will need to go to the nearest auto store and rent a pair of spring compressors... there are three bolts on the top of the strut in the engine bay and two bolts on the bottom connected to the control arm .. take the top ones off first, then the bottom.... then slide the whole component out.. put the springs compressor on the springs tighten them down till you think you are safe/ 3-4 inches.. then take off the bolt on the top of the struts.. compress the new spring and put it on the strut, then put the bolt back on and BWAMMMM you just finished one corner of your car..
She love's the way i drive her!!!!
italiano3kgt is offline   Reply With Quote
Old 03-28-2008, 05:26 AM   #3 (permalink)
Chris215's Avatar
Drives: 08 WRX
Trader Rating: (10)
Chris215 is an unknown quantity at this point
for coilovers go with ksports and that's all you need.
Yes you should replace struts as well if you go with springs, eibach springs or intrax(the most drop). It isn't too hard, but for your first time it might be time consuming.
Chris215 is offline   Reply With Quote
Old 03-28-2008, 05:26 AM   #4 (permalink)
Born In Italy
before you put the strut back in make sure the spring is in all the way, hit the top and bottom in a circular motion with a flat head and a hammer..
Old 03-28-2008, 07:54 AM   #5 (permalink)
needforspeed's Avatar
needforspeed is an unknown quantity at this point
I've got the Ground Control coilovers and they ride good but a little stiff IMO
[color=Red]FOR SALE:
2nd gen VR4 calipers
Charcoal front electric leather seats
1st gen rear garnish
Eclipse cd unit
1st gen front hub assembly
needforspeed is offline   Reply With Quote
Old 03-31-2008, 12:29 PM   #6 (permalink)
94 3000gt dohc
j3000's Avatar
Drives: 1994 3000gt
j3000 is an unknown quantity at this point
i just installed eibach, it rides pretty good, 1.5in. in the back and 1.3in. in the front. the drop is not to tremendus but looks and drives good.
j3000 is offline   Reply With Quote
Old 03-31-2008, 07:18 PM   #7 (permalink)
ImNotSpeeding's Avatar
Drives: 97 3000gt
ImNotSpeeding is an unknown quantity at this point
do you have any before and after pics?
97 Green 3/s: 3sx downpipe/Maximal Test Pipe/Custom Cat back exhaust/Ebay Intake/KYB-GR2 Struts/Ground Controls
ImNotSpeeding is offline   Reply With Quote
Old 04-01-2008, 04:13 PM   #8 (permalink)
jvc93//klze's Avatar
Drives: 93 Stealth R/T
jvc93//klze Negative 1
The blue stealth in my sig is lowered on Intrax. Ive seen cars lowered with Eibach springs and was not impressed. My buddy put them on his 94 3000GT base and the ride hight barely changed.
I'm happy with my Intrax, but had to get adjustable arms for the camber and toe.
93 Pearl Blue Stealth R/T
jvc93//klze is offline   Reply With Quote
Old 04-19-2008, 09:20 PM   #9 (permalink)
Helder 3k
so would most of you also suggest putting knew struts on as well while doing the springs? and also how hard is putting new struts on?
thanks a lot for the input guys
Old 05-20-2008, 11:07 AM   #10 (permalink)
jstarr427's Avatar
Drives: 98 SOHC Red 5MT
jstarr427 is an unknown quantity at this point
from what I've read, I'd do the struts while you're in there. so to make this clear, if I want to install a set of eibach springs and new struts, this is something I CAN do myself with basic mechanical knowledge?
So i dont need to pay a shop to do this?
jstarr427 is offline   Reply With Quote
