#22 (permalink) |
Forum user
Performance
6G72 Rebuilt w/ 3SX Stage 3 Heads (+1mm intake/exhaust) - ARP Headstuds, Wiseco 8.5:1 Forged Pistons & Kevlar Timing Belt - TD04 9B - Greddy Profec B Spec 2 Boost Controller – Greddy Turbo Timer - SSQV BOV - K&N FIPK - Dejon Tool Y-Pipe - Dejon Tool Intake Pipes - OEM 360cc Injectors - IPO Hotwire Kit - EK2 Fuel Rail Loop – eBay 3” Downpipe w/ custom Flex Section - IPO UD Pulley – RPS MAXX Street Clutch - Maximal Xcase Bracket - MSD 8.5mm Plug Wires - NGK Copper Plugs - Maximal Performance Front & Rear Solid Motor Mounts - 3SX EGR Block Off Plates - Vac. Reduction - AC Delete – Cruise Control Delete - ProSport Gauges (Boost, EGT) - Odyssey PC680 Under Fuse Box Sitting in garage: EVO 560cc Injectors - MAP ECU - WRX 13T Turbos - Krank Vents - Walbro 255 Suspension/Wheels/Brakes OEM 17” Chrome Wheels – 245/45/17 Michelin XGT Z4's Sitting in garage: RS*R Springs – Bilstein Struts – Maximal Adj Control Arms Exterior/Interior/Dress-up Autometer 2x52mm Gauge Pod - 99 Rear Center Garnish – Weevil Custom Boost Controller/Turbo Timer Mounting Plate – Snake Eyes Delete Sylvania Silverstar H4666ST – Powder Coated Upper/Lower Intake Manifold, Front/Rear Valve Covers, Y-Pipe, Waterneck, & Alternator Bracket 6G72 Engine Manual - M-Spec Vac Reduction Diagrams - My Picasa Web Album |
#27 (permalink) |
Wrenchmonkey #839
Luke: Any other clearance wheels that fit a Turbo 3S?
See this thread to buy remote IAC mounting block:
http://www.3si.org/forum/f4/f-s-remo...bodies-416611/ ![]() For sale 3.5L 6g74 Swap modified oil pans and thermostat hosuings http://www.3si.org/forum/f4/fs-6g74-...ied-3s-420690/ |
