So I have worked on this modification for the last couple months. I have now test drove it for 500 miles and revealed it at the TXG15. After running into a dozen road blocks, I finally came up with a bolt in cheap solution for a BBK for our cars that still retains the ABS. The EVO X has 355mm front brakes with large Brembo calipers that can be installed on our cars. The EVO X calipers cannot be bolted to our VR4 knuckles due to an offset issue that cannot be fixed without heavy modification to the stock knuckle. However, the EVO knuckles can be installed on a VR4 then everything bolts up. It’s a mix of certain parts but the result is a bolt up setup that works great. The ball joints and tie rod ends are different for the evo knuckles. The evo lower ball joint and tie rod end wouldn’t fit the VR4 lower A-arm and new geometry. I had to get a custom set to work with the new setup. I am making a bulk order and will sell the ball joint and tie rod kits. I am not making much on these kits, I just want to re-coop my R&D costs. Your support is appreciated
Ok so here is what you will need and approx costs.
Evo X (2008-2016) Front Brembo Calipers($400 plus used)
Evo X (2008-2016) Rotors 355mm(1 piece or 2 piece MR rotors)($60 ea plus)
Evo 8/9 (2003-2007) Steering knuckle($80- $150 plus)
9/16 or 14mm drill bit
Evo 8/9 (2003-2007) ABS sensor – just buy a knuckle with an abs sensor still installed
My new ball joint tie rod end kit( 2x ball joints, 2x tie rods ends, abs spacers) $125/kit shipped pm me(price will go up to $150 after March 31 2016)
Paypal is Apape10@yahoo.com just make sure to put for evox brake kit.
Ships 1/8/16 and upto a week after every order going forward.
Custom stainless brake line kit( Hans @ GZP has a SS kit for front and back lines https://3swarehouse.com/product/brake-line-kit-for-evo-x-brakes/).
It seems like a lot of used calipers dont have the caliper bolts with them.
You need the evox caliper bolts.
It is mitsubishi part number 4605A164
I suggest just ordering from mits dealer it was like $5 for 2 of them for me.
And they were in stock.
Other tools
(ball joint fork, ball joint press) can be borrowed from your local auto parts store.
Instructions
Remove wheels
Remove stock VR4 front brakes
Remove stock VR4 knuckles
Remove stock VR4 bearings/hubs from knuckles
Remove stock VR4 ball joints
Remove stock VR4 tie rod ends(keep stock jam nut in same location to approx locate new tie rod end)
Install new ball joint into lower A-arm
Install new tie rod end
Install stock VR4 hub into Evo 8 knuckle. (Evo 8 and VR4 have the same bearing and hub)
Install Evo 8 knuckle on car
Install ABS sensor & spacers( 2x stainless steel washers per side)
Install Evo X rotors and brakes
Install new brake lines
Install wheels
Observed Benefits
Better braking
All stock replacement parts (pads, ect)
ABS actually seems to balance out.
Less bump steer
Look cool.
Any wheel that fits an evo will fit our car.
The stance, offset and ride height stay the same.
Other tools
Instructions
Remove wheels
Install wheels
Observed Benefits
Better braking
Less bump steer
Look cool.
