Old 11-29-2006, 02:36 PM   #1 (permalink)
What the F*** Is Juice??
hockeythrasher7's Avatar
Drives: 1993 3000gt sl
hockeythrasher7 is an unknown quantity at this point
Default I need tire info!
Hi, what sort of stuff do I need to know in order for me to buy rims such as the specs and tire size and all that good stuff. I have a '93 sl. thanks in advance
hockeythrasher7 is offline   Reply With Quote
Old 11-29-2006, 03:18 PM   #2 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7
Default Re: I need tire info!
Not really sure what you're asking. Stock wheel and tire sizes are available in the service manual. For larger sizes and lists of aftermarket wheels that fit, search this (wheels/tires/brakes) forum.
Clint
The Pansy Patrol
1994 Mazda Protege DX: 260K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it
Struggly is offline   Reply With Quote
Old 11-29-2006, 03:32 PM   #3 (permalink)
i don't have my service manual, and I don't know if the tires are original. I just wanted to know like the bolt pattern
Old 11-29-2006, 03:36 PM   #4 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
114.3x5.
Clint
