#11 (permalink) |
Damage Control
Kuhmo Ecsta ASX's. They are all season, M&S rated, 420 treadware, AA traction, A temperature.
The AST's are just a step below. They are 400, A, A if I remember right
Kbizzle [11:25 P.M.]: this is most displeasing |
#13 (permalink) |
curt93T/T
General exclaim's at tire rack. I want to say 245/40/18's are $99 each. I believe the treadwear is 480
93TT Stealth, mods include: Forge dual piston open loop BOV, full ATR setup, GReddy PRofec E-01 boost controller, MAP-ECU, GT Pro "Y" pipe, Dynamic Racing DR650 + turbo's, UDP, RPS Stage II clutch with aluminum flywheel, ACCEL coil conversion, GReddy 60mm white faced boost and EGT gauges on "A" pillar with peak hold, white faced cluster gauges, Kenne Bell Boost-a-pump, denso fuel pump, Denso 660 injectors, Bob's short throw shifter, LM-1 wide band O2 sensor. 99 front end conversion with Cianci Viper hood and 1970 Boss Mustang hood pins.
