Old 03-18-2005, 01:57 PM   #1 (permalink)
Senior Member
speed3000gt's Avatar
Drives: '94 Stealth RT-TT
Trader Rating: (14)
speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7speed3000gt Level 7
Default Do slotted/drilled rotors need turning?
I just got a set of drilled rotors with 1500 miles on them and was wondering if maybe i should get them turned? Do they warp?
Thanks
You live in Texas? Come join the TX section of 3/Si -->http://www.3si.org/forum/f93/
Photobucket
speed3000gt is offline   Reply With Quote
Old 03-18-2005, 02:23 PM   #2 (permalink)
Gixxer Fixer
StealthCRF's Avatar
Drives: on empty
StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7
Default Re: Do slotted/drilled rotors need turning?
i know mine need to be lol, if you want to bring 'em by some time I can mic them and check runout
92 Stealth RT/TT Best time: 13.2 @105
StealthCRF is offline   Reply With Quote
Old 03-18-2005, 02:58 PM   #3 (permalink)
Senior Member
Trader Rating: (14)
where are you located? do you know anyone that can install them for cheap? Everywhere Ive been calling wants between 40-80 bucks... I didnt think it was that hard to change the rotors...
Old 03-18-2005, 04:26 PM   #4 (permalink)
Gixxer Fixer
StealthCRF's Avatar
Drives: on empty
sears in lewisville. i can help you put them on, but not at work, they are really anal about that kind of stuff. i would suggest putting new pads on at the same time.
