Old 12-01-2007, 09:41 PM   #1 (permalink)
jcheilig's Avatar
Drives: 91 Stealth TT
jcheilig is an unknown quantity at this point
Default Difference between Base and TT wheel fitment
Ok, I know that the brakes are larger on the TT than the base, and that is all correct? My question is, how much larger are they? I ask because I see a lot of rims that say that they fit Stealth Base, but they don't say anything about TT. I think some of them just don't want to deal with the possibility of them not fitting and having to deal with returns. Basically, if the TT calipers stick out 5mm (chose a random number) more than base then any rim that would fit a base would be guaranteed to fit TT with no more than a 5mm spacer.
If all else fails, I'll just be annoying and ask... Will these fit?
Size 18 x 8.5
Offset 35
They are Stern St-5. I read every post about the Stern St-1 that a lot of people have, some need small spacers and that would be ok. It looks to me like the st-5 spokes should be no closer to the caliper than the st-1 so it should be fine.
Any help is appreciated.
91 Stealth TT:
Y-Pipe, 3sx Downpipe, Gutted Precats, Borla Catback, Greddy Profec Type-S Boost Controller, SAFCII Fuel Controller, Fuel Pressure Regulator, 500 ft/lbs Clutch, 255 l/hr fuel pump, TurboXS RFL BOV, Avital Alarm System, 18" Stern Rims
Next to come: 550cc Injectors, 15g Turbos
jcheilig is offline   Reply With Quote
Old 12-02-2007, 06:24 PM   #2 (permalink)
Large Member
SilverBullet's Avatar
Trader Rating: (8)
SilverBullet Level 2SilverBullet Level 2SilverBullet Level 2
Default Re: Difference between Base and TT wheel fitment
Since your Stealth is a 1st gen, the brakes are basically the same size as the non-turbo brakes, so you can use wheels that say they fit the non-turbos. Heck, I think you could even use the 15" wheels that came on the base Stealths. The only TT's that have to worry about wheels due to brake size are 2nd gens, because they do have larger brake calipers.
SilverBullet is offline   Reply With Quote
Old 12-03-2007, 11:35 AM   #3 (permalink)
jcheilig's Avatar
Oh, so anything that fits a base 1st gen fits TT 1st gen?
Old 12-03-2007, 11:59 AM   #4 (permalink)
boy_genius94's Avatar
Drives: 92 vr4
boy_genius94 is an unknown quantity at this point
I thought the only difference between the 1st gen and 2nd gen brakes were the rear caliper, the knuckles that hold the calliper and rotor, and the rotors. I thought the front caliper for the 1st and 2nd gen was the same?
boy_genius94 is offline   Reply With Quote
Old 12-04-2007, 09:27 AM   #5 (permalink)
jcheilig's Avatar
I asked the guy if they gave refunds on wheels that they said fit, if they didn't fit. He asked what car I had, and I told him I had a 91 Stealth RT (though I have a turbo). His response was:
"Yes They will fit great. Clear the brakes."
So, is fitment the same for 1st gen base and TT?
Old 12-04-2007, 02:41 PM   #6 (permalink)
Large Member
Trader Rating: (8)
Yeah, 1st gen TT's can accept any size 3/S wheel, from any year. The brakes are smaller than the 2nd gen TT's, which don't accept very many rims. Finding rims for 2nd gen TT's can be hard.
Old 12-04-2007, 03:57 PM   #7 (permalink)
Drives: 92 vr4
What part on the 2nd gen brake system is different from the 1st gen besides the rotors?
Old 04-19-2008, 02:02 PM   #8 (permalink)
JeremyTwinTurbo's Avatar
Drives: 1992DodgeStealthTT
JeremyTwinTurbo is an unknown quantity at this point
Wrong!!!!!!!!! No the only difference between 1st gen and 2nd gen brakes are the rear. 1st gen have a huge 4 piston caliper like the 2nd gen but only have a 1 piston caliper in the rear the 2nd gen have 2 piston caliper in there rear.
Those wheels your oreder will most likely not fit with out spacers. I just put some rims on with spacers so they would clear the front caliper and the only thing you have worry about spacers is the wheels might stick out if you have a really thick spacers on.
Mods:3kgt Short Thorw shifter,Matrix intake,DNP Pre-cat eliminator kit,DNP downpipe,DNP 3" Test pipe,DNP cat-back exhaust w/4"tips,polished spark plug,polished upper intake plenum,Polished Wire harness cover,Carbon fiber interior dash kit,Chrome oill filler cap,R1 concepts Drilled and slotted rotors,Ceramic Brake pads,TurboXS BOV,new kelvar timing,new water pump,new oil filter housing,new motor mount,new serpentine gator back belts, katzkin leather seats,Defi BF serires guages eng temp,oil press.,boost,aluminum deforst vents,modifield DSM SMIC,DNP ic piping,big tyla ground wire kit,H4 conversion kit,vac reduction,clutch tank removed,greddy wieghted shift knob,alluminum door seals,and Setrap FMOC.
Need plastic pieces under fornt bumper. FOR 1ST GEN STEALTH DO NOT WANT ACTIEVE AERO.If you have these peices pm me or email my at: jeremytwinturbo@yahoo.com
Check out the rest of my stealth tt on cardomain:http://www.cardomain.com/ride/2417870[/]
JeremyTwinTurbo is offline   Reply With Quote
Old 04-19-2008, 03:34 PM   #9 (permalink)
i'm ridin big yo
1bad3grs's Avatar
1bad3grs is an unknown quantity at this point
no. he was right.
both first and second gen 3S have 4 piston calipers up front, but different size rotors. the first gen's rotor is smaller than the second's. therefore, any wheel that fits the second gen will fit the first but not vice versa.
1bad3grs is offline   Reply With Quote
Old 04-19-2008, 03:43 PM   #10 (permalink)
Verified Asian
Sean3S's Avatar
Drives: 94 TT
Trader Rating: (35)
Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7
I think it's a bit optimistic to say "any" non turbo aftermarket rim will fit a 1G TT...
'94 RT/TT
13T's | PTE FMIC - PPE Pipes | 560's | Supra FP w/ 8ga Hotwire | MAF-T 1.37 & LT1 Blow-Through | E-Manage Blue w/ Boomslang Harness | HKS DLI | Stillen Downpipe | Gutted Rear Pre-cat | Borla Catback | Tial BOV | AEM FPR & Rob Beck Adapter | DejonTool Intake Pipes | PWR Radiator w/ IPS Pipes | FAL Fans | MP Motor Mounts | 99 Lash Adjusters | Clevite 77 Rod & Main Bearings | Leatherseats.com Dk. Graphite w/ Red Center Seats | Sparco Flash 5 Black w/ Red Alcantara | Spec Stg. 2 Clutch & 3SX Clutch Line | 3SX Crank Pulley | Bob's SS Shifter & All Solid Bushings | NGK Coppers & MSD Wires | eK2 EGR Blockoffs | eK2 Fuel Line Loop | PST 1 Pc. CFDS | Volk LE37T | Falken FK452 | Tein S-Tech Springs | Adj. Rear Control Arms | Slotted Rotors w/ Hawk HPS Pads | GReddy Profec B | AEM UEGO WB | GReddy PWH Boost, EGT, GReddy OP, FP, Temp | Hybrid Logger | McColluch 5300K HIDs | Shaved '99 Bumper & Turns | VIS Hood
295.7 AWHP / 310.3 TQ @ 1 Bar - BPU @ TX04
Collecting Dust - CM Oil Filter, Setrab Oil Cooler, Snow Stage 2 Meth, Brake Lines, Megan Coilovers
Some Day - ABS Delete, Ducting
WTB - ek2 Harness Cover (above the fuel rails)
Sean3S is offline   Reply With Quote
