Re: Deep Dish Rims???
i have 18x10 24mm offset. my offset makes a bit more sense...since my rims are wider. they definately stick out; however, if you compare the stock n/a wheels and the volks--you'd see that the volks are effectively just adding more tread towards the outer edge. the overall amount of tire inside the wheel well is effectively identical.
