Control arms, What exactley do they do? - 3000GT/Stealth International Message Center
Old 05-10-2006, 09:26 PM   #1 (permalink)
The MoonShine Man
jrod's Avatar
Drives: 1xxx Whp
jrod Level 1jrod Level 1jrod Level 1
Feedback Score: 46 reviews
Default Control arms, What exactley do they do?
I just got my tein s techs. And was wondering whay exactley control arms would do for me. I have been told i need them but never why. Thanks, Jared
2002 Viper: Twin Turbo:Infinityuilt:E100
1995 VR4: Twin 5857:AEM:Stroker:E100
1997 Supra: Stock Twins:Upgrades Soon
1994 Stealth: Stock Twins:Upgrades Soon
2007 FJ: 6" RC Lift: 35's on XD Addicts
jrod is offline   Reply With Quote
Old 05-10-2006, 09:32 PM   #2 (permalink)
Crank up the boost!
TuRbO3K's Avatar
Drives: 93 VR
TuRbO3K is an unknown quantity at this point
Feedback Score: 11 reviews
Default Re: Control arms, What exactley do they do?
sounds like your talking about adjustable control arms. considering you already have control arms, which is what your steering knuckle pivots on and for suspension travel. some people say you need them on 2G's for alignment. it's to get the camber/alignment adjustments back in spec, although after lowering your car i dont think it'll ever be the same pretty sure adjustables are for the rear....hope this helps
Todd
93 VR4 BPU
12.89 @ 107.80 - 1.83 60'
06 600RR
TuRbO3K is offline   Reply With Quote
Old 05-10-2006, 09:34 PM   #3 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Struggly Level 1Struggly Level 1
Feedback Score: 5 reviews
The stock control arms are not adjustable; you adjust camber by turning the cam bolt on the lower arm. The range of adjustment is small.
when you lower the car, you alter the suspension arm angles such that you have a lot more negative camber than you should have (this is an oversimplification, but anyway).
Adjustable control arms allow you to force the rear knuckle into a more upright position, thereby getting your rear camber in spec.
Clint
1987 BMW e30 325is: Bilsteins/H&R, VERY solid motor mounts, pointless bullshit deleted
1994 Mazda Protege DX (retired): 296K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it
Struggly is offline   Reply With Quote
Old 05-10-2006, 09:35 PM   #4 (permalink)
The MoonShine Man
jrod's Avatar
Drives: 1xxx Whp
Ya thats what i meant. But so the tire wear will be really fast right.
Old 05-10-2006, 09:36 PM   #5 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
The rear tires will wear prematurely on the inner edge and your car will be more prone to understeer.
Clint
Old 05-10-2006, 09:42 PM   #6 (permalink)
Crank up the boost!
TuRbO3K's Avatar
Drives: 93 VR
the most critical tire wear angle is toe...my camber is about 1.5 degrees negative in the rear and i think a little more in the front from lowering my car with intrax. i havent had any problems with inner tire wear to this day....just keep up on rotating your tires! hahaha
Old 05-10-2006, 09:48 PM   #7 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Primary reason for avoiding excessive negative camber in rear is tendency to understeer anyway. 1.5 degrees neg. camber is fine if running 2.5-3 in front.
Clint
Old 05-10-2006, 10:00 PM   #8 (permalink)
This, too, shall pass.
JoshAnker's Avatar
Drives: 95 Stealth
JoshAnker Level 2JoshAnker Level 2JoshAnker Level 2JoshAnker Level 2JoshAnker Level 2
Feedback Score: 31 reviews
I have some for sale... take a look at this thread:
http://www.3si.org/forum/showthread.php?t=328154
If you want to see what your tires will look like WITHOUT them, take a look here:
http://www.fatsurfer.com/3si/forsale/badcambersized.JPG
Take a look at the top tire, and the second tire down in particular... notice how only one side of it has tread left Read my thread, there's some good info in there... and the control arms are still for sale if you'd like them.
JoshAnker is offline   Reply With Quote
Old 05-10-2006, 11:04 PM   #9 (permalink)
The MoonShine Man
jrod's Avatar
Drives: 1xxx Whp
Looks like i will be getting some then. And joshanker thats a really good deal but these are for my vr-4. Thanks for all the input guys.
Old 05-11-2006, 03:38 PM   #10 (permalink)
Now with100% less Stealth
leet's Avatar
Drives: 95 NSX / 05 IS300
leet is an unknown quantity at this point
Feedback Score: 24 reviews
you can make your own for about $105
no more stealth
fullerfotos.net
leet is offline   Reply With Quote
