Old 06-19-2008, 03:14 PM   #1 (permalink)
Hubbell86's Avatar
Drives: 1992 Stealth R/T TT
Trader Rating: (7)
Hubbell86 Level 1Hubbell86 Level 1
Default Buying wheels for TT and need help
I was just woundering if these would clear the calipers and if they would even really fit.
Wheel Details - Discount Tire Direct
Thanks Chase
1992 Dodge Stealth R/T TT (41,700 original miles!)
Mods: 3sx TP, 3sx DP, Emanage Blue, 15gs installed, Running 20 Psi (Getting Tuned by Predator Performance!) Walbro 255, 450cc injectors, Meth inj.
1992 Dodge Stealth R/T NA
Mods: 3sx DP, 3sx TP, and Ebay Intake
Hubbell86 is offline   Reply With Quote
Old 06-19-2008, 05:05 PM   #2 (permalink)
soaking it up
nawz8r's Avatar
Drives: '91TT '02Avalanche
Trader Rating: (6)
nawz8r Level 3nawz8r Level 3nawz8r Level 3nawz8r Level 3
Default Re: Buying wheels for TT and need help
The bolt pattern is correct, 17's are the stock 1st gen size, although most would agree 18", or poss 19" would be the size to upgrade to, with 8.5 or 9" width. You need to know what the offset (ET) is also. Normally, offsets of 35 - 40 are good for the TT's, however rim design can vary and cause caliper clash, so have the seller make sure they will work on your car before buying. If interested in wheel info - Car Bibles: Everything you need to know about wheels, tyres and tyre markings.. Good Luck - it's quite a trek shopping for wheels - so many models, yet only so many will fit 3S TT's. Also, think about the look you'd like to achieve.
1991 TT. K&N FIPK, DNP Y-pipe, '99 lifters, Greddy RS BOV, Tein S Techs, 3SX DP, H-flow cat, Moda MD1 19x8.5
nawz8r is offline   Reply With Quote
Old 06-19-2008, 07:13 PM   #3 (permalink)
Hubbell86's Avatar
Trader Rating: (7)
so im guessing 17 offset is no good lol
Old 06-19-2008, 07:38 PM   #4 (permalink)
soaking it up
nawz8r's Avatar
Trader Rating: (6)
They would stick out quite a bit beyond the fender, like approx 24mm, or just under 1".
Old 06-20-2008, 03:11 PM   #5 (permalink)
Hubbell86's Avatar
Trader Rating: (7)
well would it clear the caliper? i can change the wheels for inspection
Old 06-20-2008, 03:15 PM   #6 (permalink)
Hubbell86's Avatar
Trader Rating: (7)
what about these?
MB Wheels Weapon [Part#: 53638]
Old 06-20-2008, 08:26 PM   #7 (permalink)
soaking it up
nawz8r's Avatar
Trader Rating: (6)
At 27mm offset, they will stick out approximately 14mm imo. Some people don't mind if they protrude beyond the fenders - more aggressive look, however, as close as possible to even is my preference. Don't care for sand blasting my fenders as the tires pick it up, as well as H20 spraying up roostertail fashion. The caliper question still needs to be answered by the vendor, or manufacturer of the specific rim. If they say yes the calipers will clear, then they should take them back - return shipping paid if they don't.
Old 06-20-2008, 08:37 PM   #8 (permalink)
Hubbell86's Avatar
Trader Rating: (7)
lol thats problem ive been on 3 websites and there are pretty much 0 wheels for a TT. Discount Tire has 4 sets of wheels...
Old 06-20-2008, 09:00 PM   #9 (permalink)
Drives: VR4
buffalo_vr4 is an unknown quantity at this point
call them. they will know and will tell u if it fits.
buffalo_vr4 is online now   Reply With Quote
