I just got done changing a Passenger drive axle, and I also changed all four rotors, pads, and brake lines. After I did this I bled the hell out of the brakes. When I first started driving it the brake light didn't come on. After about 1/4 mile it came on. I figured low fluid, but I checked it and it was fine. What could the problem be? Needs to be bled some more?
Shawn MacArthur New Ride - 1997 Dodge Viper GTS - Twin Turbo
1600+ hp on C16!!! - 1170hp on pump gas @14.5 PSI!!!
Sold!! - 1992 Black 3000GT VR-4, Evo 16G Turbos, JPDC Adapter Plates, Denso 720cc Injectors, Apex'i Super AVC-R Boost Controller, Spec Stage 3 Clutch, Greddy Emanage, Walbro fuel pump, Accel coils and 8.8 mm wires, HKS Type 1 Turbo Timer, Intrax Springs, Stillen Downpipe, Borla Exhaust, Gutted precats, Greddy Type-S BOV, Unorthodox Underdrive Pulley, NGK plugs, Snake eyes, New carpet, floor mats, and custom leather two-tone interior, 99 front end conversion, custom built FMIC.
If in changing the brake lines the master cylinder was allowed to completely drain then the master cylinder needs to be bled:
1) Cover the area under the master cylinder with enough towels to absorb a good amount of brake fluid
2) Disconnect the master cylinder outlet
3) Fill the master cylinder resevoir
4) Have some one depress the brake pedal
5) Place a finger over the master cylinder outlet
6) Raise the brake pedal
7) Repeat steps 4-6 at leat 4 times
Then bleed the brake lines with the engine running in the order of passenger rear, driver front, driver rear, passenger front. The engine needs to be running to insure that the ABS pump is fully bled of air.
I think I have the same problem, after changing the brake lines to 3SX SS-lines, I also changed the brake fluid and first pumped the old fluid out as much as I could. I also bled the brakes wrong at the first time, engine not running and in wrong order :O I bled them again yesterday, but the ABS light still comes on after 20-30 seconds. The brakes take very sharply though, if there was air in the master cylinder, wouldn't that make the pedal soft?
Where is this master cylinder located, below the reservoir?
thanks, Elina
Originally Posted by mdcrose
Shawn,
-Michael
I have never heard of anyone bleeding the master cylinder separate from the rest of the brakes......
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
It's in the service manual and I practice I have always followed if the master cylinder is emptied.
When you remove your finger from the outlet of the master cylinder air will get into the master cylinder so is the goal of "bleeding" the master cylinder to push a little less air through the brake lines??
Clint
The instructions included with a master cylinder I changed recently on another vehicle stated bleeding was necessary to ensure proper priming.
Clint
Air will not get in as the resevoir is above the outlet and when you remove your finger fluid will try to come out. Then just put on the brake line and bleed the system as normal.
Got it - but there will still be air in the brakes line when you connect it to the master cylinder. And while I agree that I saw the procedure in the service manual, I do not see that it offers much benefit because you still have to bleed every bubble of air from the wheel cylinders. (This procedure just pushes a little less air through the brake lines on the way to the wheel cylinder bleeders.)
