Old 05-27-2008, 07:56 PM   #11 (permalink)
resident evil
wraith's Avatar
Trader Rating: (15)
wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7
Default Re: Brake Caliper Pistons - How Easy to push in?
I cant do them with my fingers. I just did the brakes on my 2005 GTO and it needed the c-clamp as well. They just warn you not to push them in too hard or crooked but thats really hard to do.
wraith is offline   Reply With Quote
Old 05-27-2008, 09:20 PM   #12 (permalink)
Pearl White 92 Stealth TT
mike92stealthtt's Avatar
Drives: 100+ IDC's
Trader Rating: (12)
mike92stealthtt Level 7mike92stealthtt Level 7mike92stealthtt Level 7mike92stealthtt Level 7mike92stealthtt Level 7mike92stealthtt Level 7mike92stealthtt Level 7
I just use some huge channel locks that are taped up to protect my caliper. I never tried using just my hands but I'll give it a try next time and maybe I'll be able to join the macho man club of 3si.
mike92stealthtt is offline   Reply With Quote
Old 05-27-2008, 11:40 PM   #13 (permalink)
nikg3kgt
nikg's Avatar
Drives: 94 3000gt vr4
nikg Level 1nikg Level 1
I also did them with my hands. The fingers were sore for the rest of the day.
TD05 is coming!!!
nikg is offline   Reply With Quote
Old 05-28-2008, 04:56 AM   #14 (permalink)
In Training
etecnifibre's Avatar
Drives: 99 3/4 Ton Silverado
Trader Rating: (64)
etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7
LOL. I must have really "easy" calipers. My hands are NOT the "farmer/sausage" hands as described above, not even close.
Maybe it's from squeezing that mail all day, yeah, that's gotta be it.
etecnifibre is offline   Reply With Quote
Old 05-28-2008, 12:14 PM   #15 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (65)
So I guess it's alright to have resistance to movement in those pistons. I was worried that since they were so hard to move, the calipers were both bad. Sounds like it's normal, except if your car is ungodly clean and nice like etecnifibre's ride.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 05-28-2008, 02:13 PM   #16 (permalink)
Me=yellow You=purple
chrisincobb's Avatar
Drives: SHORT DISTANCES
chrisincobb Level 7chrisincobb Level 7chrisincobb Level 7chrisincobb Level 7chrisincobb Level 7chrisincobb Level 7chrisincobb Level 7
this is the first time i ever heard of anybody doing it bare- handed. i would never have even tried that. i just use a good old c-clamp and a block of wood (to keep the pressure even) and a turkey baster to remove some fluid from the master cylinder. i hope i never shake hands with you guys OUCH!
chrisincobb is offline   Reply With Quote
Old 05-28-2008, 08:28 PM   #17 (permalink)
In Training
Trader Rating: (64)
I must have something special going on here.
Like I said, I was quite surprised that they went in with me pushing with my hands. I worked at Cummins midrange engine plant, and there were some older fellows there with "ungodly" strength. They had big, fat hands, could carry the crank around like it was a toothpick, flip a shortblock around like it was a feather, etc. I never did understand it!
Maybe I was just lucky!
Old 05-28-2008, 08:47 PM   #18 (permalink)
94 3000gt dohc
j3000's Avatar
Drives: 1994 3000gt
j3000 is an unknown quantity at this point
one really easy way is before you take the caliper off, get a flathead screw driver and put it between the piston and the brake pad, then pull towards you (meaning that the screw driver will press the piston in). Just a thought... but other then that just use a press, very easy and simple.
Photobucket
j3000 is offline   Reply With Quote
Old 05-28-2008, 08:53 PM   #19 (permalink)
Praise RaptorJesus!
sammage's Avatar
Drives: bugeye wagon
Trader Rating: (25)
sammage level 6sammage level 6sammage level 6sammage level 6sammage level 6sammage level 6
Originally Posted by bluemax_1 View Post
Here's another way to do it (yeah using your bare hands can be a little tough).
When you remove one side of the used pads, you then have enough wiggle space to fit a prybar to against the other used pad to squeeze the pistons back in. Leave the cap open on the brake master cylinder though.
Max
This is how my redneck Ford buddy showed me, works great. Especially since the line on the inside of the caliper make the C-clamp less than ideal.
Originally Posted by Predacon View Post
PS. Everyone be nice in this thread, mean people suck!!!!
sammage is offline   Reply With Quote
Old 05-28-2008, 09:05 PM   #20 (permalink)
Norcal3S.com
slage's Avatar
Drives: 92 VR4 // 96 Jeep ZJ
Trader Rating: (60)
slage Level 7slage Level 7slage Level 7slage Level 7slage Level 7slage Level 7slage Level 7slage Level 7slage Level 7slage Level 7slage Level 7
that method won't work on 1G rear's though
13T's + Supporting Mods|DSM SMIC's|K-Sport Coilovers|Battery in Trunk
Alchy Injection|Saner Sway Bars|Bronze 17x9 FN01R-C's|3" Straight Pipe
1996 Grand Cherokee: My DD, 4" Lift and 31" Tires
1992 VR-4: My Weekend Warrior
slage is offline   Reply With Quote
