Old 05-02-2008, 05:21 PM   #1 (permalink)
O_ROD's Avatar
Drives: 1991 RT/TT
O_ROD is an unknown quantity at this point
Default Bilsteins and stock bumpstops.
After some extensive searching, and reading Oohnoo's expertise on suspension, I just have one question left...
I just received my Bilsteins/Tein's and they are ready to go in. I know the internal bumpstops will be fine with the Teins but what do I do with the stock ones? Can I completely remove them or should I trim them?
Thanks
O_ROD is offline   Reply With Quote
Old 05-02-2008, 05:23 PM   #2 (permalink)
DSM GURU
Mike1992's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (25)
Mike1992 is an unknown quantity at this point
Default Re: Bilsteins and stock bumpstops.
I'd trim them, as riding without them can be quite jarring on hard bumps where the shock bottoms itself out.
1992 Mitsubishi 3000GT VR-4 RIP 3/06
1990 Eagle Talon TSI AWD - 11.29@126 - SOLD
1991 Dodge Stealth RT/TT - Traded
1992 Eagle Talon TSI AWD - Where fast really is cheap
Mike1992 is online now   Reply With Quote
Old 05-02-2008, 05:28 PM   #3 (permalink)
GTCUL8R
Polygon's Avatar
Drives: '89 GTC & '91 R/T TT
Trader Rating: (11)
Polygon Level 2Polygon Level 2Polygon Level 2
Also, bottoming out dampers can damage them.
Polygon is offline   Reply With Quote
Old 05-02-2008, 05:34 PM   #4 (permalink)
O_ROD's Avatar
Drives: 1991 RT/TT
thanks guys, but would it be damaging and jarring even with the internal bumpstops in place?
Old 05-02-2008, 06:15 PM   #5 (permalink)
GTCUL8R
Polygon's Avatar
Trader Rating: (11)
Not unless the bump stops are cracked and worn. They could give to the point where the damper bottoms out.
Old 05-03-2008, 08:50 AM   #6 (permalink)
'96 VR4
tachyon_ftl's Avatar
Drives: It's spos'd to move?
Trader Rating: (11)
tachyon_ftl is an unknown quantity at this point
Huh. According the directions that come with the Teins, you trim 1-1/2 inches off the fronts, and nothing off the rears. Since the Bilsteins have internal bump stops, do you still need the front bump stops at all? What do the Bilstein install instructions say about the external bump stops on the strut you're rebuilding?
tachyon_ftl is offline   Reply With Quote
Old 05-03-2008, 12:13 PM   #7 (permalink)
Forum user
Monster Stealth's Avatar
Drives: 93 VR4 & 99 A4 1.8T
Trader Rating: (24)
Monster Stealth Level 2Monster Stealth Level 2Monster Stealth Level 2
On the Bilsteins you do not reuse the stock bumpstops. You need to pull the housings off the bilsteins and trim them ones that are internal.
9b 13.2 w/ 93 Pump
Originally Posted by Ron Burgundy
Lot Lizards Love Salisbury Steaks
Monster Stealth is offline   Reply With Quote
