#21 (permalink) |
Lethal, nope, still got the stock parking brake in there. The rotors are (or were at least) sold by SCE to be upgrades for the rear stock brakes. Came with a bracket to remount the stock 2G rear caliper a little farther out to fit the larger diameter rotor.
'92 Stealth RT/TT, Sandstorm, 125K miles
Currently installed: E-MBC, SS brake lines, Motul 600 BF, FN01R-C rims, ATR DP, test pipe, and exhaust, EK2Mfg EGR blockoff plates, MAFT-Pro, S-ITC, Dejon Tool intake runners, JIC FTL-A2 struts, PST CFDS, Tial BOV, MSD 8.5mm plug wires, Accelerated Motorsports catch can, Ebay FMIC, Evo 560's, IPO dual feed fuel lines, Greddy P/W/H EGT gauge, IPO battery relocation, Optima red top, PWR radiator, DSM shifter bushings, custom WW fluid tank, Saner F/R swaybars, PLX WB O2 setup, SCE StopTech ST-40 332x33 front brake upgrade & 300mm rear rotors, SCE tender springs, SCE caster/camber plates, Titan Bending f header, 15G turbos,forged crank, Crower rods, Weisco pistons, DR Stage 2 heads, TRS seats, 5 pnt harnesses. |
#23 (permalink) | |
July 2003
Max
1994 3000GT VR-4. Hobbies... what are hobbies? Oh, those things people do when they're NOT working on their cars?
#24 (permalink) |
will work for turbo
Is this thread still alive? I have an 96 NA and planning to hit the track some time soon. I'm considering investing in a BBK. I was looking at the Stoptech 328x28mm kit for the 91-99 NA. Are they any good? They're like $1700+ so it's quite an investment for me but do I really need it for track use? I understand that the bigger rotors can withstand more heat and dissipate them more effectively. Can anyone chime in on that kit or do I need to go with the Brembos? Do I only need to upgrade the front?
K&N FIPK|3SX front & rear polyeurathane motor mounts|3SX downpipe|Maximal Performance testpipe|Unorthodox under drive pulley|HKS dual SS exhaust|NGK platinum spark plugs|NGK spark plug wires|Maximal Performance wire kit|ACT stage 2 semi-racing clutch|Tein Flex complete coilovers|3SX front tower bar|Cusco rear tower bar|custom rear sway bar|18x9.5 Bronze 5zigen FN01C-R|265/35/18 Toyo Proxes R888 semi-slick tires|Bomex front lip spoiler|GTO MR Titanium shift knob|custom short throw shifter|Razo pedals| Momo Tuner steering wheel|Corbeau CR1 racing seats|Corbeau 4pt racing harness|Stoptech 4-piston 328x28 Big Brake Kit|Deftracing 575 Carbon Fiber hood|Koyo radiator|
#25 (permalink) |
NG '03 6th Floor Crew
If you are going to the track for the first time... I would NOT spend any money on "upgrades", merely buy a set of decent street/strip pads, and a spare set of rotors. Go out, have fun, and if it is something you want to continue to do... spend your money when you need to. I ran for two years on stock brakes.
If you want a good read. Browse my thread on "tips for taking your 3000GT/Stealth to the track". http://www.3si.org/forum/showthread.php?t=306660
Web log: http://apps.blackflagracing.com/Blog/
The Armada '93 Sandstone Gray 3000GT VR-4 2006 3SI Ride of the Year 2007 All Mitsu Cookout, 1st Place 1st Gen 3/S 2008 All Mitsu Cookout, 1st Place 1st Gen 3/S '92 Fiji Blue 3000GT VR-4 2004 All Mitsu Cookout, 1st Place 1st Gen 3/S 2005 NG Quick 8 AWD Unlimited 1/4 Mile Qualifier. BLACK FLAG RACING '92 Emerald Green Pearl Stealth RT/TT 3.5L, 15Gs, AEM EMS For Sale |
#27 (permalink) | |
Smooth and Fast
I've had the AP kit for a number of years now. Only a few issues overall. Not a biggie, but due to rotor temp the once anodized black hat, is now gold. Here's the biggie.. The first race I had with these they performed very well. ATF fluid freshly bled, 3" brake coolers, and the Pagid pads, worked like a charm. However, when returning to the shop to refresh the car for the next day, I found that a number of the bolts that hold the hat to the rotor had broke. Yes, broke. Bolt part still in there, but the nut side was now gone. I had 3-4 bolts left on each rotor that were still intact, scary stuff. A quick phone call to AP, told them story, and they waived the $180 for shouldered race bolts. They came with bolts that were threaded all the way down, apparently an option that I was not informed of during the purchasing process. Oh well, all has been good since with the upgraded harware. Short story, sorry for straying off topic.. The Stoptech's are awesome. I know a number of racers that use them and love them. I would listen to Max and find a good sized rotor for the fronts. Bigger is better when it comes to heating. Like Max said, it's a heat sink. The longer it takes to heat them, the better the cooling ducting will work, and ultimately a better performing braking system. Rotors will be replaced at some point, so look at replacement costs too. You can always to go to a different rotor as well. Even larger if you want to fab up new brackets. The calipers you'll hopefully have for a long time, so look into rebuild kits. Make sure they offer rebuild kits. Also look into whether or not they have dust boots. Those are critical for keeping the seals alive over extended periods of time. If you plan on endurance racing look into the removal of the pads, can it be done quickly? That's one of the main reasons I went to the AP's, they can be swaped in seconds, not minutes. (as long as your pit guy doesn't burn himself and run away like a little sissy, but that's another story) Even though i've never owned a set of stop techs, I would certainly recommend them, they have an awesome rep in the industry and they perform well from what i've seen. Take a look at Willwood too just for comparison.... Erron S. |
#28 (permalink) | |
AWD Road Racing Fanatic
). I love my set and so do all of my customers. Philip
Supercar #1 - 1995 R/T TT
- 3SNG'08 Autocross 1st place and F.T.D. - 3SNG'05 Autocross 1st place and F.T.D. - 1:33 Lap Time at Gingerman - 2:35 Lap Time at Road America Supercar #2 - 1994 R/T TT ------------------------------ Supercar Engineering : http://supercar-engineering.com Ksport Suspension Kits Billet Transmission Shift Forks, 300M Shafts, LSD, Transmission Rebuild Parts STOPTECH Brake Kits, Big Reds, and custom brake upgrades bonanza! 3/S Open tracking parts, Carbotech, Porterfield and Axxis Ultimate high-performance Carbon Ceramic and Kevlar Ceramic brake pads, and more products to come. Already here: a Dog Box, SCE Torsen Center Diff, OBX and Quaife Front Diff, KAAZ Rear Diff, Dry Sump Oil System, Ohlins/Moton/KW/more Suspensions. |
#29 (permalink) |
Wilwoods are good only to be looked at for comparison, that's right. They are only a cosmetic upgrade, compared to most others.
I used to make AP kits but after a while all of my customers were settling on StopTechs, so I decided to keep things simple and offer only them. |
