#1 (permalink) |
I am buying a set of Axis Hiro rims. The have looked and looked for an exact rear offset. I will be running a staggered set up:
19x8.5 35mm offset Front 19x9.5 25mm(??) Rear A few people on here commented that "Ford" was running a 20mm offset in the rear(he has the exact setup I looking at). The lowest I can find for these rims is a 25mm offset. If anyone knows please let me know.
93mm Ross Pistons,Pauter Rods,3SX Port and polished heads,Webcams race cams,ARP main/head studs,South Bend Stage 4"FE" clutch,720 cc injectors,Supra fuel pump,IPS FMIC, IPS TD05 headers/EVO III turbo kit,Tanabe exhaust, Hiro Axis 19x9.5 rear 8.5 front, Toyo Proxes T1R 285 rear 245 front
#2 (permalink) |
i can make your vtech cry
i'm not sure about the offset unless you don't mind the rims sticking out a centimeter or so? probably more for the rear. you generally want to keep it between 36-42offset range. stock offset is 46 which is what you want to be close to.
