Went to discount tire yesterday to test fit a 19x8.5 32mm offset Drag DR53. As expected, it didn't clear the front caliper. I was planning to run that in the front and a 19x9.5 +35 in the rear.
I am extremely picky about wheels, and the only other two that I'm liking at the moment are the P45F/P45R combo's and maybe a staggered TSW Bardo combo. I'm set on running 19's staggered.
I've searched many thread, and see that a P45R 9.5" +30 will clear front and rear, but my question is will a P45F 8.5" +35 clear the front?
EDIT:
For the Drag DR53's It took me about 9mm worth of washers to space the wheel out enought to clear the caliper. So that's an effective +23mm offset. If anyone can put a dimension the the amount that they have shaved down their calipers, that'd be great. 5mm shave + 5mm spacer may be worth it..
EDIT:
