Old 01-26-2006, 11:55 AM   #1 (permalink)
maxpain's Avatar
Drives: 91 vr4
maxpain is an unknown quantity at this point
Default 94 vr4 stock offset
Just a quick question, what is the offset on the stock 94 vr4 rims?
maxpain is offline   Reply With Quote
Old 01-26-2006, 11:59 AM   #2 (permalink)
Luke@tirerack is an unknown quantity at this point
Default Re: 94 vr4 stock offset
17x8.5 ET46
Luke@tirerack is offline   Reply With Quote
Old 01-26-2006, 03:26 PM   #3 (permalink)
maxpain's Avatar
Drives: 91 vr4
What kind of problems would I run into if I put a rim with a 40 offset on a 94 vr4? It is a 17x8.5 but just with a 40 offset(would I need to use spacer).
Old 01-27-2006, 02:57 AM   #4 (permalink)
maxpain's Avatar
Drives: 91 vr4
anyone?
Old 01-27-2006, 02:43 PM   #5 (permalink)
maxpain's Avatar
Drives: 91 vr4
Still no replys, here is the link
http://www.discounttiredirect.com/di...vid=008303&bp=
will any of these fit a 94 vr4 without fitment problems
I know tirerack has a nice pair for $189 each but they are on back order until the end of March.
Old 01-27-2006, 03:56 PM   #6 (permalink)
40 offset wheels will fit a VR aas long as the wheel choice has enough brake clearance
Old 01-27-2006, 04:16 PM   #7 (permalink)
maxpain's Avatar
Drives: 91 vr4
Thanks for the help luke, would have been going through tirerack but I need the the rims asap and you guys are out of stock
Old 01-27-2006, 04:17 PM   #8 (permalink)
so, you're saying we do not have ANY wheels instock for your car ....... that can't be what you're saying is it?
Old 01-27-2006, 09:23 PM   #9 (permalink)
maxpain's Avatar
Drives: 91 vr4
No thats not what I am saying, what I am saying is you are out of stock of the 17's from $189, the other 17's you offer are $325. Thats a big difference in price and I didn't want to spend that much more.
Old 01-27-2006, 10:40 PM   #10 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Struggly Level 1Struggly Level 1
A lower offset means that the wheel hub is further in relative to the outside edge of the wheel. In other words, the lower the positive offset, the farther out the wheel moves. So, in theory, those +40mm offset wheels are fine. But there are other things to consider; brake caliper clearance (often dictated by hub shape) is first among them, as Luke said.
Clint
The Pansy Patrol
1994 Mazda Protege DX: 260K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it
Struggly is offline   Reply With Quote
