Old 04-23-2008, 12:38 PM   #11 (permalink)
SJ
W3SI Co-founder
SJ's Avatar
SJ is an unknown quantity at this point
Thumbs up Re: 91-93 Rear calipers, 94 and up rear calipers
Originally Posted by 1HOT VR4 View Post
Yes, the 2G calipers have 2 pistons vs 1G 1 piston. You can change them fairly easily. Trimming the dust shield I think is all you have to do. I'll be swapping over to all 2G calipers and rotors!
I'm planning on doing the same someday soon as well.
I have Goodridge SS lines, but I thought I heard you may need the 2G longer rubber lines from the caliper if you plan on using the stock lines. I cannot confirm this though.
Anyone? Fry? Bueller? Anyone?
SJ
2nd Place - DSM Shootout - 3/S Class ‘01
ECG Road Runner Award '03
2nd Place - Car & Driver PRO Series - GT2 Class '05
2nd Place - Best First Gen - National's Car Show '06
3rd Place - Best First Gen - National's Car Show '07
ROTM August '07
Racing is life. Everything else is just waiting.
SJ is offline   Reply With Quote
Old 04-25-2008, 07:03 AM   #12 (permalink)
Dago Red Vr-4 is an unknown quantity at this point
Default Re: 91-93 Rear calipers, 94 and up rear calipers
SJ ,just did the conversion from Gen 1 to Gen 2 F&R . I used Goodridge SS lines and all 4 corners were fine on length . So no you do not need longer lines on the rear . You must trim the splash shield to accomodate the larger rear rotor . I used Carbotech slotted rotors and pads ,Ax-6 on the front and Bobcats on the rear . Also I had to shim the rear caliper to center it to the rotor . You will not regret it . The difference is very noticeable .My personal preference is ATE blue or gold brake fluid but that is up to you . Good luck . Steve
Dago Red Vr-4 is offline   Reply With Quote
Old 04-25-2008, 02:14 PM   #13 (permalink)
Stuff and Junk and Things
EvanH's Avatar
Drives: NO PASSENGERS!!
Trader Rating: (7)
EvanH is an unknown quantity at this point
would it throw off any performance with just doing the rear?
EvanH is offline   Reply With Quote
Old 04-25-2008, 07:55 PM   #14 (permalink)
SJ
W3SI Co-founder
SJ's Avatar
Lightbulb Re: 91-93 Rear calipers, 94 and up rear calipers
We need Phil from SCE to jump in here, but I would say your language may be off -- it will certainly improve performance, but, it *may* offset the balance of the factory brake bias setting, which we cannot adjust.
Now, will it make a huge difference if it's just a daily driver? I can't answer that. However, I bet I would be able to feel it at the track.
I'd recommend you do them both at the same time.
SJ
