Old 04-12-2008, 07:27 PM   #1 (permalink)
Stuff and Junk and Things
EvanH's Avatar
Drives: NO PASSENGERS!!
Trader Rating: (7)
EvanH is an unknown quantity at this point
Default 91-93 Rear calipers, 94 and up rear calipers
One, obviously there is a difference, but what is it other than look, and type of pad it takes? Two, would it be worth it to swap the 1st gen with a 2nd gen set? And three how easy would a swap be?
EvanH is offline   Reply With Quote
Old 04-12-2008, 07:34 PM   #2 (permalink)
mk_
Drives: Rx-8
Trader Rating: (12)
mk_ is an unknown quantity at this point
Default Re: 91-93 Rear calipers, 94 and up rear calipers
I dunno I asked the same question and was answered that they were all the same
3/S N/A brake question
Premier P880PRS running active (SOLD)
Boston Acoustics Z6; mids --> JBL Px300.4 @ 3 ohms bridged (Keeping)
Seas Neo 27TAFNC/G; tweeters --> Axionixx 400.2 @ 4 ohms (Keeping)
Fi Car Audio 18" BTL Fully Loaded (SOLD) --> Crunch GP3000D @ 1 ohm (SOLD)
5.00 cf enclosure after displacement (BURNED)
Optima Yellow Top (Keeping), 3 Additional Yellow Tops (Electrical) (SOLD)
EA 200amp HO Alternator (PM Me)
Street Wires 0/1 Gauge Power wire (2 runs-PM me)
Knuconceptz 0/1 Gauge Ground wire
0/1 Gauge Big 3 Upgrade
mk_ is offline   Reply With Quote
Old 04-12-2008, 07:44 PM   #3 (permalink)
EvanH's Avatar
Trader Rating: (7)
TT brakes is what I'm asking about.
Old 04-12-2008, 07:46 PM   #4 (permalink)
mk_
Drives: Rx-8
Trader Rating: (12)
Didnt even look at your car
Free bump for you
Old 04-14-2008, 12:19 AM   #5 (permalink)
resident evil
wraith's Avatar
Trader Rating: (16)
wraith Level 2wraith Level 2wraith Level 2wraith Level 2wraith Level 2wraith Level 2
I thought the first gen rear TT calipers were single piston floating while the 2nd gen rears are 2 piston fixed
wraith is offline   Reply With Quote
Old 04-14-2008, 02:16 AM   #6 (permalink)
Verified Asian
Sean3S's Avatar
Drives: 94 TT
Trader Rating: (37)
Sean3S Level 1Sean3S Level 1
Correct, the 2G's are also 10x better looking in addition to being better calipers.
'94 RT/TT
13T's | PTE FMIC - PPE Pipes | 560's | Supra FP w/ 8ga Hotwire | MAF-T 1.37 & LT1 Blow-Through | E-Manage Blue w/ Boomslang Harness | HKS DLI | Stillen Downpipe | Gutted Rear Pre-cat | Borla Catback | Tial BOV | AEM FPR & Rob Beck Adapter | DejonTool Intake Pipes | PWR Radiator w/ IPS Pipes | FAL Fans | MP Motor Mounts | 99 Lash Adjusters | Clevite 77 Rod & Main Bearings | Leatherseats.com Dk. Graphite w/ Red Center Seats | Sparco Flash 5 Black w/ Red Alcantara | Spec Stg. 2 Clutch & 3SX Clutch Line | 3SX Crank Pulley | Bob's SS Shifter & All Solid Bushings | eK2 EGR Blockoffs, Fuel Line Loop, Injector & Harness Cover | PST 1 Pc. CFDS | Volk LE37T | Falken FK452 | Megan Racing Coilovers | Adj. Rear Control Arms | Slotted Rotors w/ Hawk HPS Pads | GReddy Profec B | AEM UEGO WB | GReddy PWH Boost, EGT, GReddy OP, FP, Temp | Hybrid Logger | McColluch 5300K HIDs | Shaved '99 Bumper & Turns | PRM Style Hood
295.7 AWHP / 310.3 TQ @ 1 Bar - BPU @ TX04
Collecting Dust - Setrab Oil Cooler, Snow Stage 2 Meth, Brake Lines, Solid Diff Bushings
Some Day - ABS Delete, Ducting
Sean3S is offline   Reply With Quote
Old 04-14-2008, 05:55 AM   #7 (permalink)
EvanH's Avatar
Trader Rating: (7)
so what's the chances of swapping them?
Old 04-23-2008, 12:30 AM   #8 (permalink)
EvanH's Avatar
Trader Rating: (7)
bump for the week
Old 04-23-2008, 12:32 AM   #9 (permalink)
Twin turbo toy
1HOT VR4's Avatar
Drives: 92 VR4
Trader Rating: (37)
1HOT VR4 is an unknown quantity at this point
Yes, the 2G calipers have 2 pistons vs 1G 1 piston. You can change them fairly easily. Trimming the dust shield I think is all you have to do. I'll be swapping over to all 2G calipers and rotors!
GT368SX-R's, Stage III Heads, Webcam street grind cams, New 4-bolt main w/ Venolia Pistons & Pauter rods, Fidanza aluminum flywheel, Spec stage 3+ clutch, Denso 720cc injectors, GT-PRO custom headers, DNP Precat eliminators, Fidanza cam gears, 1-piece PST CFDS, AEM EMS, AEM UEGO, AEM Tru Boost controller, Synapse Synchronic BOV, Denso Fuel pump, Billet adjustable actuators, MSD ignition, IPS polished intake pipes w/ dual AEM air filters. Intrax lowering springs, Pitroad-M dual-titanium exhaust, Victory hood, Koyo Aluminum radiator, Flexalite fans, Setrab oil cooler, IPS FMIC, NOCAR billet T-Case, Solid motor mounts, Supercar racing oil-pan, short shifter, Stillen DP, Black leather Recaro racing seats, 2nd gen brakes & steering wheel, JDM GTO rear center garnish, Kaze front bumper lip, ETOH injection...& more Carizzma deep candy red paint. Volk 18x9 GT-C wheels with Bridgestone Potenza RE0-1R's.
1HOT VR4 is offline   Reply With Quote
Old 04-23-2008, 02:01 AM   #10 (permalink)
EvanH's Avatar
Trader Rating: (7)
can you make a post for the conversion? or pm me the steps for the rear?
