Why does my shifter feel loose when its in gear? - 3000GT/Stealth International Message Center
Old 09-21-2007, 11:23 AM   #1 (permalink)
ral1239 is an unknown quantity at this point
Feedback Score: 0 reviews
Default Why does my shifter feel loose when its in gear?
Its loose in neutral and in the rest of the gears. When its in gear you can kinda shake it left and right. feels a little loose. How can i fix this?
ral1239 is offline   Reply With Quote
Old 09-21-2007, 11:37 AM   #2 (permalink)
B-Man0660's Avatar
Drives: '92 Stealth TT
B-Man0660 is an unknown quantity at this point
Feedback Score: 7 reviews
Default Re: Why does my shifter feel loose when its in gear?
New bushings
'92 dodge stealth r/t TT - 13Ts@18psi on pump, PTE 680cc injectors, 255lph fuel pump, Crushed DSM BOV, FMIC, EMU stage 3 MAFless, DP, 3" custom single shot exhaust, RS-R Lowering Springs
B-Man0660 is offline   Reply With Quote
Old 09-21-2007, 11:59 AM   #3 (permalink)
needforspeed's Avatar
needforspeed Level 2needforspeed Level 2needforspeed Level 2needforspeed Level 2needforspeed Level 2needforspeed Level 2
Feedback Score: 3 reviews
This is the exact same problem I have with mine. Whats the cost involved.
"You need people like me so you can point your fuc*in fingers and say that's the bad guy" ~ Scarface
needforspeed is offline   Reply With Quote
Old 09-21-2007, 12:14 PM   #4 (permalink)
Paid Member
Stealthee's Avatar
Drives: 1994 Stealth
Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3
Feedback Score: 151 reviews
Its the set up of the shifter. Pull the boot off to see what I mean. Our shifters arent directly connected to the trans, they are connected by cables. I bet if you put it in 5th theres little "slop" at all.
I have solid shift bushings and I have the same "slop"
Old 09-21-2007, 01:04 PM   #5 (permalink)
mine is an automatic
Old 09-21-2007, 01:58 PM   #6 (permalink)
I've been here way too long
Venom13132's Avatar
Drives: Small Block Chevys
Venom13132 Level 1Venom13132 Level 1
Feedback Score: 113 reviews
automatic or manual whatever. The assembly is just mounted to the exhaust/drive shaft hump. its just your bushings that make it loose like that. You can tighten some of the bolts in there to clean up some of the play. Now if we were talking about a car where the shifter is directly mounted into the transmission then you might have some problems.
Current Cars: 1995 RX-7 LS1; 2003 Avalanche Z71; 1994 Miata MX-5; 92 Stealth R/T
Venom13132 is offline   Reply With Quote
Old 09-21-2007, 03:51 PM   #7 (permalink)
B-Man0660's Avatar
I know bushing helped mine quite a bit. Yes, there's still 'slop' but it's normal
Old 09-28-2007, 05:52 AM   #8 (permalink)
will work for turbo
ewang9394's Avatar
Drives: 1996 DOHC NA 5spd
ewang9394 is an unknown quantity at this point
What do you mean by "slop?"
ewang9394 is offline   Reply With Quote
Old 09-28-2007, 03:35 PM   #9 (permalink)
How hard is it to replace or tighten the bushings. anyone have a writeup. and the price of new bushings.
Old 09-28-2007, 03:42 PM   #10 (permalink)
Broken hip
Drives: 91 stealth base
XrZrX is an unknown quantity at this point
there like $8 a piece at the dealership
theres 2 diff types white and black. you can find them on 3sx.com for cheaper.
mine was really loose and then i switched the bushings and it helped alot
XrZrX is offline   Reply With Quote
