what's the difference between vr4 engine and na engine? - 3000GT/Stealth International Message Center
Old 05-16-2005, 08:07 AM   #1 (permalink)
Drives: 1992 3000GT SL
SportLuxury is an unknown quantity at this point
Feedback Score: 0 reviews
Default what's the difference between vr4 engine and na engine?
All I know is that it has less compression....uhh, why do some people do swaps? How does it help if you don't do turbos? Thanks
SportLuxury is offline   Reply With Quote
Old 05-16-2005, 08:10 AM   #2 (permalink)
Theoretically awesome.
Caffinated Soap's Avatar
Drives: '93 3kGT
Caffinated Soap is an unknown quantity at this point
Feedback Score: 11 reviews
Default Re: what's the difference between vr4 engine and na engine?
Lower compression + No turbos = even slower. If anyone has ever done a VR-4 motor swap, they had forced induction in mind.
The only difference aside from compression is an extra set of oil squirters on the pistons. That's it.
Elements of the past and the future, combining to make something not quite as good as either.
The Caffy Factor™
Caffinated Soap is offline   Reply With Quote
Old 05-16-2005, 09:37 AM   #3 (permalink)
I see, so it would be useless to have a vr4 motor in there if you don't plan on doing turbos... It has lower compression so that there would be less knock when turbos are used? Thanks
Old 05-16-2005, 09:38 AM   #4 (permalink)
Maybe it'd be good if you don't want to use premium gas... so the lower compression can allow that without a turbo.....hmm...
Old 05-16-2005, 09:51 AM   #5 (permalink)
Paid Member
Stealthee's Avatar
Drives: 1994 Stealth
Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3
Feedback Score: 151 reviews
IT would be a flat out dog if you didnt use turbos. NA's are rated at 222 hp with the 10:1 pistons. Rated being the key word. They probably make 205-210hp at the crank. With 8:1 pistons and no turbos its only going to be like 180hp, so it will be about as good as a SOHC, only with an extra 1000 rpms. Its not worth it just so you dont have to use premium gas. Premium will cost you about $3 more per fill up than 87 and if you cant afford that then sell the car.
Old 05-16-2005, 08:23 PM   #6 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Hannibalzero is an unknown quantity at this point
Feedback Score: 61 reviews
The 8:1 compression pistons aren't really designed to reduce knock as much as they allow the engine to push more boost. You would be able to run 9-11 psi (stock for 1st and 2nd gens, respectively) on 10:1 compression, but it probably won't be as reliable for a fleet of engines. (Yes, I know IPO can run 17+ psi, but Mitsubishi doesn't have a warranty on the engine).
There are also a number of other differences between the two engines. The 93+ turbo engines have forged cranks and 4 bolt main bearings. NA (like the 91-92) do not. Also, the turbo engines (not sure if it is 93+, or all years) have additional oil squirters.
Old 05-16-2005, 08:26 PM   #7 (permalink)
H to the izzO
Drives: Recklessly
Oh yeah, different oil pan too. There's a number of other small differences. You can search to find the specifics. The bottom line is you probably don't want to run a TT block without turbos unless you just have one lying around - and then you would be better off selling it to buy an NA motor (assuming you plan to stay NA).
Old 05-16-2005, 08:29 PM   #8 (permalink)
roguetrip's Avatar
roguetrip is an unknown quantity at this point
Feedback Score: 3 reviews
I heard the Camshafts are different between the two as well. I believe the oil jets where in all TT/VR4 Motors
'92 Dodge Stealth ES DOHC ATX
Snake Eyes, Topline Engineering Ground Kit, Intake Resonator Removed, Rebuilt ECU&TCU, VentusII HR Tires
NGK Laser Platinum Spark Plugs, HyperBlack 18x9 ET36 Saleen Replicas waiting to go on!
'90 Dodge Daytona ES V6 (6G72)
MTX A543 3.77FD, Optima RedTop, KYB's all around, 58mm TB, 2.5" CAI, 1" intake spacers, BPE underdrive pulley, Strut tower bar, solid motor mounts, Fidanza Aluminum Flywheel
+ more
roguetrip is offline   Reply With Quote
Old 05-16-2005, 08:32 PM   #9 (permalink)
Ninja Performance
Import Power's Avatar
Drives: Vicki Insane
Feedback Score: 221 reviews
17?
My battle with Multiple Myeloma/Non Curable Blood Cancer
91VR4-3.0L-Stock heads and Cams-835AWHP 747AWTQ Daily Driver 10.31@142mph on street tires
SLTT-10.9 @ 142MPH Stock NA engine and NA heads/Cams
T4 AWD 9.21 @ 154.98 (Chris Hill Driver/Builder/Tuner Car Owned by 3SX)
T2 FWD 10.19 @ 140.31 (Chris Hill Driver/Builder/Tuner Car Owned by 3SX)
T4-159.23 MPH Ran on 6G72 3.1L! (Chris Hill Driver/Builder/Tuner Car Owned by 3SX)
T4-995AWHP Uncorrected 6G72 3.0L C16 (Chris Hill Driver/Builder/Tuner Car Owned by 3SX)
T2-820FWHP 3.1L 27psi C16 (Chris Hill Driver/Builder/Tuner Car Owned by 3SX)
Old 05-16-2005, 08:32 PM   #10 (permalink)
Ninja Performance
one of them is identical, the other is different
