#1 (permalink) |
Forum user
Need help here. Removed my oil pan and in my oil pan I had a small spring about 1/2 inch long, 1/16 inch wide and one small steel ball about 1/16 inch in size in the bottom of the pan. Would anybody have an idea of where it came from?
1994 Mitsu 3000gt vr4 only 8,700 miles, Evo3 16g turbo's with tdo5 manifolds and down pipes, 8:1 wiseco forged pistons, pauter forged rods, 780 injectors, aem engine management, billet fuel rail, spec 3 plus clutch and pressure plate, Spec flywheel, aem filter, aem fuel pressure regulator, front mount intercooler, greedy profec boost controller, hks ignition amplifier, aftermarket oil cooler. alcohol injection.
#3 (permalink) | |
Forum user
My main bearings went out that was why I took the oil pan off. The oil pressure had lowered somewhat before taking the oil pan off. Engine started making a slight noise and I checked it soon. So the small spring and steel ball is what you think made my mains fail. |
#4 (permalink) |
Did you post this in the wrong section? Are we talking about your VR4?
I was thinking poppet valve for one of the piston skirt oilers. Got pics?
Because One broken Stealth just wasn't enough... I made twins.. |
#6 (permalink) | |
Forum user
I don't have a way to post pics or I would. It is a black spring and small perfect round shinny ball (like a ball bearing). What color is the oil pump relief spring or piston squirters? Is the ball I am referring to called a plunger in the service manual or is it out of a piston squirter? If it was the oil pump regulator valve the plug the manual refers to was not in my oil pan. Any help would be apprectiated!!!!!!! |
#7 (permalink) | |
I don't know how you can check them without pulling the crankshaft. I hope this isn't your problem but maybe someone near you has an old oil jet so you can see if the parts match. New ones are only $9.00 each from a Mitsusbishi dealer. Only problem is the crank must be out to change them. Good luck. |
#8 (permalink) | |
Forum user
Thanks for the info. |
