Old 04-17-2008, 03:16 PM   #1 (permalink)
jlfx car audio's Avatar
Drives: 97 3000gt sl
jlfx car audio is an unknown quantity at this point
Default were to get a timing belt?
i have a stock sohc daily driver it has 87,000 on it and i am going to do a
new timing belt ,tensioner,waterpump,plugs wires ,tps, cap/rotor/fuel filter, and vave cover gaskets are their good and bad water pumps/timing belts
autozone,O'Rilyes as colse to the same price on all
napa is 2x higher on pump and belt and the dealer is 3x higher
does anyone have any preferance on any of this stuff
jlfx car audio is offline   Reply With Quote
Old 06-17-2008, 01:30 PM   #2 (permalink)
dbeltran24's Avatar
Drives: 3000GT SOHC ATX
dbeltran24 is an unknown quantity at this point
Default Re: were to get a timing belt?
Auto Parts Fast at RockAuto has some pretty decent prices on this stuff. I need to replace the same parts and was also wondering if anyone knew what was a good brand. For instance for the timing belt I have found four brands on the listed site: Gates, Dayco, Acdelco, and Sealed Power. Any recomandations?
MODS - INTAKE (Installed), BigTyla Ground Wires (Installed), Ultimate Performance Strut Bars (Front: Installed / Rear: Not installed yet), 3SX Polyurethane Suspension Bushings (Purchased, but not installed yet), Polished DOHC Throttle Body (Purchased, but not installed yet)
I really need to find the time to install parts I buy
Edit: Finally found time to install some parts, but not all.
dbeltran24 is offline   Reply With Quote
