Old 11-27-2008, 03:34 AM   #71 (permalink)
JDM 3.5L 6G74 yo!
TUFFTR's Avatar
Drives: Mitusbishi Magna
TUFFTR is an unknown quantity at this point
Default Re: TT Conversion Bible
What the "joint" on the rear of the engine block?
3.5L DOHC 24v | Gates Blue Belts | Blue Silicon Radiator Hoses | Polished 3000GT TT Intake Manifold | Braided S/S Fuel Lines | Custom Aluminum Intake | 3" Pod | Adaptronic Aftermarket Engine Management | 3SX Lightweight Crank Pulley | Fidanza Adjustable Cam Gears | Iridium Spark Plugs | 10mm Racing leads | 5sp w/Exedy HD clutch | Malpassi Ajustable fuel pressure regulator | 3 Bar MAP Sensor - Oil catch Can -
195FWHP NA 3.5L
TUFFTR is offline   Reply With Quote
Old 11-27-2008, 11:04 AM   #72 (permalink)
Drives: 98 sl
Trader Rating: (15)
98slept is an unknown quantity at this point
Oil Pressure to Block Adapter All 3S*-*Mitsubishi 3000GT*/*Dodge Stealth
the third end attaches to the rear turbo feed line
98 SL TWIN TURBO
Alpha/Omega Gauges In the Works!!!
aka Worlds Most Badass 3/S Led & Ultraviolet Gauges/Needles.
My CarDomain Page>>>http://www.cardomain.com/ride/2257248
98slept is offline   Reply With Quote
Old 01-05-2009, 02:40 AM   #73 (permalink)
Nb1320's Avatar
Drives: 94 3000GT, 07 Silv.
Nb1320 is an unknown quantity at this point
Well once again I am amazed at this forum and comradery or however the hell you spell that word, lol. And again this site and its members are helping me to achieve one my of my New Years resolutions, becoming a 3S wizard. I didn't get a chace to go through all of the pages, because its late and I got to work in 6 hours, but what I read I didn't see any mention of a TT ECU, I am doing a TT conversion in my 94 3000gt this month, beginning of Februrary and want to make sure I get all of the right parts ordered and in on time to get it done by mid next month. Can I use the ECU in my base or will I need a TT ECU? I know this post is old and all, so has anything changed, new problems come up, or anything else that a "newcomer" to the 3S world should know about? I have lots of questions and i'm sure that when I get to read more and take the time to go to more of the links that everyone has posted I will get ALOT of my answers, but as of tonight, I only have 2 questions. Another thing is I was told that I needed to get a VR4 engine, is this true? Anyways, thanks for reading and I hope someone can help.
Thanks,
Justin
Injen Short Ram Air Intake...
More mods to come!
Nb1320 is offline   Reply With Quote
Old 02-07-2009, 12:36 AM   #74 (permalink)
Adam
Sindeas's Avatar
Drives: 94' White 3000GT
Sindeas is an unknown quantity at this point
very nice I hope to one day Convert though not to sure if it good for a auto trany lol.
Sindeas is offline   Reply With Quote
Old 03-03-2009, 04:55 PM   #75 (permalink)
Attack Tiger's Avatar
Drives: 1993 VR-4
Attack Tiger is an unknown quantity at this point
I've heard the ATX can be a lot of fun when it's beefed up with a tranny cooler and a high-stall TC. I even read about a particular member that had hers converted to a "manumatic" push-button shift configuration. Sounds pretty badazz.
Attack Tiger is offline   Reply With Quote
Old 07-21-2009, 11:11 AM   #76 (permalink)
thanos3kgt is an unknown quantity at this point
Originally Posted by Iceman3K15 View Post
bump for those who haven't seen it
Hey Iceman, i read your thread on ur TT swap... great work and good looking car..
The picturres don't seem to come up, the link to the gallery requires a password... Any way u can get the pictures working??
also care to comment on the end result?? How much pressure u are running? Any numbers u are making?? Most importantly how does ur car handle with the LSD???
Thanks, i am in the middle of my swap as well...
thanos3kgt is offline   Reply With Quote
Old 09-10-2009, 01:27 PM   #77 (permalink)
Drives: 96
mhdofg is an unknown quantity at this point
hey ice man!! i have just orderd a JDM rear subframe and im going to be doing the conversion soon, i probably wont have access to a vr4 body to get those front studmount/panels (the spot welded ones) so i was wondering if you think it would be safe to just mount it to the rear studs like you did but the "fab" some front studs and mounting plates to distribute the load a little better? i have custom built an entire tubular frame for a 55 ford before and i think this should be WAYYYYY less complicated than that was lol.. what u think?
mhdofg is offline   Reply With Quote
Old 10-21-2009, 02:48 AM   #78 (permalink)
I <3 my 3000GT
gilrod7's Avatar
Drives: 1992 3000GT SL
gilrod7 is an unknown quantity at this point
thanks for that link. I was looking for that part.
Mods: Injen intake, NGK iridium spark plugs, test pipe, custom exhaust, kevlar timing belt, 3sx custom crank pulley.
gilrod7 is offline   Reply With Quote
