Old 10-30-2003, 02:00 PM   #31 (permalink)
rahhhmonster is an unknown quantity at this point
Default Re: TT Conversion Bible
i just wanna know. does the SL tranny work with the vr4 engine or do you have to make adjustments?
rahhhmonster is offline   Reply With Quote
Old 10-31-2003, 12:15 PM   #32 (permalink)
gecko1's Avatar
Trader Rating: (8)
gecko1 is an unknown quantity at this point
I'm pretty sure the sl tranny does not work with the VR4 engine.
All your answers can be found with one click of the search button
CURRENT: 1995 Stealth TT, 1996 3000GT SL - 100% stock
PAST: 1994 3000GT NA - 14.2@95 mph, 1991 Stealth TT
gecko1 is offline   Reply With Quote
Old 10-31-2003, 02:14 PM   #33 (permalink)
The Codebringer
Gatecrasher's Avatar
Drives: 02 SVT Focus
Trader Rating: (7)
Gatecrasher Level 1Gatecrasher Level 1Gatecrasher Level 1
An FWD tranny works just fine.
Try searcing yourself before you post misleading information. If you're not sure of what you're saying, at least tell people that so that they can take your post with a grain of salt.
Gatecrasher is offline   Reply With Quote
Old 10-31-2003, 03:10 PM   #34 (permalink)
TajMan's Avatar
Drives: 93SOHCMTX
Trader Rating: (25)
TajMan is an unknown quantity at this point
Hey Gatecrasher, what is involved in using a an AWD tranny in a FWD car? I assume you just leave the transfer case off and then alter something inside the tranny so it doesn't even turn the output shaft to the t-case. Does it work with the N/A shifter and linkage or do you have to get that from the TT as well. Does the AWD tranny on a FWD car hold up better than the FWD tranny without a LSD on either?
former 3/Ss: '92 R/T, '94 3KGT, modded '92 R/T TT
current vehicles owned that are down for builds:
'93 Stealth
'77 Lancia Scorpion
'79 Yamaha XS11
TajMan is offline   Reply With Quote
Old 10-31-2003, 07:33 PM   #35 (permalink)
gecko1's Avatar
Trader Rating: (8)
"The AWD tranny can't really be converted over to FWD only"
taken from a post made by gatecrasher
http://www.3si.org/forum/showthread....nny+fwd+engine
I'm probably wrong about this one two. I guess i just don't have a lot of salt.
For some reason in the last post i made i was thinking he was trying to put an awd tranny in a fwd car. Just got mixed up. Wasn't thinking straight.
Old 10-31-2003, 07:40 PM   #36 (permalink)
SoCal3S.com
xtremewlr's Avatar
Drives: 1995 3000GT FWD
Trader Rating: (8)
xtremewlr is an unknown quantity at this point
Actually, I beleive that Gatecrasher later prooved himself wrong about that by putting an AWD tranny (6 speed) into his FWD TT swapped car. I know that a custom plug would have to be made to plug the hole left by removing the output shaft but I dont know what the details are and what else might need to be done to the tranny. Maybe Gatecrasher could be so kind as to enlighten us on this? It is a swap that I would deffinatly consider later on.
Check out #vr-4 on irc.sportscarweb.com
Whats IRC??
xtremewlr is offline   Reply With Quote
Old 10-31-2003, 08:17 PM   #37 (permalink)
TajMan's Avatar
Drives: 93SOHCMTX
Trader Rating: (25)
Thats why I asked gatecrasher, I know he's done it, and I think a few others have too.
Old 10-31-2003, 10:30 PM   #38 (permalink)
serboy's Avatar
Drives: '99 SOHC
serboy is an unknown quantity at this point
Question for Iceman3K15 ........
Is this TT swap for SOHC engine too or just for DOHC ???????????
DA SERB
serboy is offline   Reply With Quote
Old 11-01-2003, 02:50 AM   #39 (permalink)
3/S Addict
Iceman3K15's Avatar
Drives: 1994 RT/TT
Trader Rating: (10)
Iceman3K15 is an unknown quantity at this point
You thread hijacking bitches! But really, Gate does have the 6spd tranny. I would love to do that but I don't want to have to deal with all the customizing. One of the tuner shops should take AWD 6spd trannies (used), and do the modifications needed to make them fit on a NA. Then sell them as ready to bolt on 6spd's. I would pay the extra cash for a 6spd, and that would be my next mod!!!
Serboy - this is TT conversion is for DOHC's only. SOHC's need to do the full vr4 engine swap.
1994 RT/TT DR Turn Key Car, SOLD but never forgotten
Intake/Turbos/Exhaust: ARC2 w/82mm MAS, Apex ITC, Greddy Type-S BOV, DR-650s, DN o2 housings, ATR downpipe, ATR Single-Shot Cat-Back
Fuel: Denso Fuel Pump, Hot wire kit, Denso 720cc Injectors, Snow Performance Methonal Injection
Ingition: MSD 8.5mm ignition wires, NGK 9's at .024
Engine: new Mitsu shortblock, 3rd gen lifters, Unorthodox lightened crank pulley
Control: Blitz DSBC, Blitz FATT, Greddy Boost and EGT gauges
Drivetrain: 3SX S/S clutch hose, RPS Max Street Disc Clutch, RPS flywheel, cross drilled rotors w/ stainless braided brakes lines, 5Zigen FN01R-C 18x9.5s, Kuhmo Ecsta Supra's 265/35/18
Other: 3SX poly motor mounts, DR carbon fiber spark plug cover, 99 front end, carbon fiber hood, 15% tint
1994 SL TT 8:1 motor swap, Quiafe LSD, etc. SOLD
Iceman3K15 is offline   Reply With Quote
Old 11-01-2003, 03:21 AM   #40 (permalink)
Banned from selling
Drives: 1998 3000GT FWD TT
SpeedFreakSteve is an unknown quantity at this point
Thats the #1 thing I hate about this forum. Way too many people posting "so-called" information, when they're really just guessing. People should refrain from answering unless they actually know the answer to something.
SpeedFreakSteve is offline   Reply With Quote
