» Site Navigation
» Related Sites
» Buyers Guide
» Network Links
3si.org is the premier 3000GT/Stealth International Forum on the internet.
Registered Users do not see the above ads.
10-26-2003, 06:10 PM
#21 (permalink )
3/S Addict
Drives: 1994 RT/TT
JeremyC - I got the OEM parts from here:
http://www.mitsupartsdirect.com/ you cannot beat their prices
1994 RT/TT DR Turn Key Car, SOLD but never forgotten
Intake/Turbos/Exhaust: ARC2 w/82mm MAS, Apex ITC, Greddy Type-S BOV, DR-650s, DN o2 housings, ATR downpipe, ATR Single-Shot Cat-Back
Fuel: Denso Fuel Pump, Hot wire kit, Denso 720cc Injectors, Snow Performance Methonal Injection
Ingition: MSD 8.5mm ignition wires, NGK 9's at .024
Engine: new Mitsu shortblock, 3rd gen lifters, Unorthodox lightened crank pulley
Control: Blitz DSBC, Blitz FATT, Greddy Boost and EGT gauges
Drivetrain: 3SX S/S clutch hose, RPS Max Street Disc Clutch, RPS flywheel, cross drilled rotors w/ stainless braided brakes lines, 5Zigen FN01R-C 18x9.5s, Kuhmo Ecsta Supra's 265/35/18
Other: 3SX poly motor mounts, DR carbon fiber spark plug cover, 99 front end, carbon fiber hood, 15% tint
1994 SL TT 8:1 motor swap, Quiafe LSD, etc. SOLD
10-26-2003, 07:22 PM
#22 (permalink )
3/S Addict
Drives: 1994 RT/TT
I posted some pics! Check 2nd post where I said I would put them.
10-27-2003, 04:08 AM
#24 (permalink )
Drives: 91VR4/02 R/T durango
dam thats bad ass if your ever in phoenix and wana maybe try to do that agian just let me know -Eric
Eric
Engine: Ferrea Stainless Steel Valves, Dual Springs, Titanium Ret, Locators AAM Spec. JE Pistons, Crower Rods, Unorthodox UnderDrive pulley, GT-Pro368’s, AEM ems, RC750cc, MSD ignition coils/ wires, 3sx Krank vents, EGT block of plates, 3rd gen lifters, Hotwired Supra Pump, Blitz Turbo Timer, Profec-B EBC, ATR exhaust, ATR down pipe, no cats, Greddy Type S, short shifter, greddy intake, RPS Flywheel, ACT heavy duty clutch, 25spline conversion, DSM SMIC, DNP hardpipe kit, SS Brake Lines, t-case braket, 3sx fuel rail loop
Body/Interior: Tenzo R Race Buckets, 2x White Face Greddy EGT's, Greddy White Face Boost, Greddy White Face Oil Pressure, AEM wideband, Cianci triple gauge pillar, 2nd Gen VR4 calipers/rotors, 99 OEM spoiler, 95+vr4 chromes, Nitto 555, Intrax Springs, polished v cover, polished plenum, GTO polished spark plug cover, polished fuel rails, 99 conversion
Soon To Come: Cianci Victory Hood, Cianci widebody fenders, Volk TE37's, poly motor mounts
Soon to be installed just taking up space.
Kaze front lip, Bomex side skirts,
10-27-2003, 12:23 PM
#25 (permalink )
blk93stealthes
Drives: 94 Pearl Blue VR-4
heh the non turbo plenum cought me off guard
1994 Pearl Blue VR-4
10-27-2003, 01:41 PM
#26 (permalink )
newbie
You have an injector resistor pack listed as a required part.
How did you get it to work with the N/A ecu and wiring harness ?
'91 ES - Twin turbo conversion
aka - punkasscrab2
10-28-2003, 04:28 AM
#27 (permalink )
3/S Addict
Drives: 1994 RT/TT
I have it listed as a required part because the TT injecotrs run at a low inpedence and the NA injectors run at a high impedence, so you need it to get them to a low impedence. Now I haven't figured out how to hook it up yet, I have talked to a member who said he had it done. I need to get back with him and get some pictures. Or I will end up having to do what you did with the inline injectors for each seperate injector.
10-28-2003, 09:07 PM
#28 (permalink )
Drives: into things
question,
If someone wwere to use 1 turbo, say a front one... would the rear joint be neccessary, or just the oil filter bracket?
10-29-2003, 05:44 PM
#29 (permalink )
Drives: '99 SOHC
hmmmmmmmmmmm...
Is this conversion for SOHC engine too or is just for DOHC ?????
DA SERB
10-30-2003, 11:57 AM
#30 (permalink )
Re: TT Conversion Bible
For some reason i don't see anything about needing intercoolers and all the intercooler pipping. Very good info... ...will be using it all very soon
