Old 10-23-2003, 12:33 AM   #1 (permalink)
3/S Addict
Iceman3K15's Avatar
Drives: 1994 RT/TT
Trader Rating: (10)
Iceman3K15 is an unknown quantity at this point
Thumbs up TT Conversion Bible
FWD TT Conversion
Parts list – with prices below:
-Turbos from a VR4, either the TD04 9b’s or TD04 13G’s with wastegate actuators
-Both intercooler and all piping associated
-Exhuast manifolds and the manifold gaskets from a VR4
-o2 housings and precats from a VR4
-Oil housing from a VR4
-Oil feed and return lines for the turbos, and all the eyebolts and gaskets
-“Joint” on the back of the engine block for the rear oil feed line
-Modified non-turbo oil pan to accept oil return lines
-Water housing from a VR4
-Water feed and return lines for the turbos and all the eyebolts, washers, and gaskets
-VR4 downpipe
-360cc injectors
-VR4 fuel pump (or walbro 255ltr/hr)
-Injector resistor pack
-Front motor mount bracket
-Oil cooler with lines
electronics needed:
-S-AFC or S-AFR
-Boost gauge
-Air/Fuel ratio gauge
-Exhuast Gas Temperature gauge (two is best, one for front bank and
one for rear bank)
-Pocketlogger – useful for monitoring everything, especially knock
Ok I was able to get many things used from various members on the 3SI board in the “Parts for Sale” section. So my advice is to just watch the section and when something comes available that you need, pick it up. I got the turbos, exhaust manifolds, precats and some of the piping for $210 shipped, but the turbos needed new wastegate actuators which were $145. I picked up the intercoolers and piping for $175 shipped. I picked up the oil and water housings for $60. I got the 360cc injectors for $75, the walbro fuel pump for $73, the resistor pack for $63, and the TT downpipe for $70. The front motor mount bracket was $40. The oil cooler was $110. I picked up the S-AFC (gen 2) for $260, the boost gauge, air/fuel gauge, and the double gauge pod for $235 (I got some nice gauges). I am going to eventually get two EGT gauges, and a pocketlogger; but I did not right now to help keep costs down as they are not absolutely mandatory. The long list of OEM parts that included all the oil, coolant, and water lines with the bolts, and gaskets from the dealership for $256. I also picked up various bolts, silicon gasket maker, and vacuum hose for the wastegates which all cost approximately $15.
In my search for parts I came across a Manual Boost Controller for $15 and decided to pick it up. It was not mandatory for the conversion, but I heard the MBC helps to prevent boost spiking.I hadn’t changed my spark plugs in a while either so I picked up some new denso iridium IK24’s for $63.
Now when doing the TT conversion you add a lot of power, so your transmission is going to need some beefing up to being able to handle it. When my clutch went out I got a RPS Stage 2, so I was ok in that area. But I still had the stock open differential which cannot handle the extra power. Therefore, I decided to go ahead and get a Quaife LSD. Now the LSD is not cheap and not mandatory for you TT conversion to run, but I would not chance not having it, especially if you plan any trips to the track or drive your car hard. The LSD and parts needed to install it ran me $1,050 shipped….nice chunk of change. It cost me around $350 in labor to get the LSD installed, so do it yourself if you can.
So to add it all up,
TT conversion parts.........$1,787
Non mandatory stuff.......$78
Drivetrain parts...............$1,050
LSD Install.......................$350
____________________________
TOTAL..............................$3,265
For a parts list including all OEM part numbers:
TT Conversion Parts List
For the complete step by step HOW TO I used on the install:
TT Conversion How To
To install the S-AFC I used this link:
Apexi S-AFC Install
To install the gauges I used this link:
Air/Fuel Gauge Install
To install the fuel pump I used this link:
Fuel Pump Install
(click on "Garage" then scroll down to fuel pump)
To install the injectors I used this link:
Injectors Install
(click on "Garage" then scroll down to injectors)
Much thanks goes out to Jeff Lucius, and 3SX Performance for the use of their extremely helpful websites, and the whole 3SI message board and its many members who helped me along the way (especially SLguy who was always answering questions for me). Good luck on all the TT conversions to come. I hope this will serve a good reference to help anyone out who wants to do the conversion in the future!!
1994 RT/TT DR Turn Key Car, SOLD but never forgotten
Intake/Turbos/Exhaust: ARC2 w/82mm MAS, Apex ITC, Greddy Type-S BOV, DR-650s, DN o2 housings, ATR downpipe, ATR Single-Shot Cat-Back
Fuel: Denso Fuel Pump, Hot wire kit, Denso 720cc Injectors, Snow Performance Methonal Injection
Ingition: MSD 8.5mm ignition wires, NGK 9's at .024
Engine: new Mitsu shortblock, 3rd gen lifters, Unorthodox lightened crank pulley
Control: Blitz DSBC, Blitz FATT, Greddy Boost and EGT gauges
Drivetrain: 3SX S/S clutch hose, RPS Max Street Disc Clutch, RPS flywheel, cross drilled rotors w/ stainless braided brakes lines, 5Zigen FN01R-C 18x9.5s, Kuhmo Ecsta Supra's 265/35/18
Other: 3SX poly motor mounts, DR carbon fiber spark plug cover, 99 front end, carbon fiber hood, 15% tint
1994 SL TT 8:1 motor swap, Quiafe LSD, etc. SOLD
Iceman3K15 is offline   Reply With Quote
Old 10-23-2003, 12:34 AM   #2 (permalink)
3/S Addict
Iceman3K15's Avatar
Drives: 1994 RT/TT
Trader Rating: (10)
Default
front engine pic
side engine pic
other side
Here are some pics for those of you who don't know what some of the parts look like:
Oil Housing
Water Housing
Old 10-23-2003, 12:48 AM   #3 (permalink)
Thiswon'ttakelongdidit
gamoparracing's Avatar
Drives: R/T and Vette
Trader Rating: (9)
gamoparracing is an unknown quantity at this point
Default
Good job man
1994 Dodge Stealth - Getting Twin Turbos
1994 Dodge Stealth - In pieces
1998 Corvette - Sleeping
1990 Nissan Truck - Really wants twin turbos
gamoparracing is offline   Reply With Quote
Old 10-23-2003, 06:24 AM   #4 (permalink)
eru
Official Member
eru's Avatar
Drives: 1999 3000GT SL-4
eru is an unknown quantity at this point
Default
That's a nice list. Thanks for helping us out.
I hope this gets pinned.
636WHP @ 26 psi / 478WHP @ 14psi
FWD NA -> AWD TT aka "SL-4"
Information about my car -> "SL-4"
92 Stealth TT (back-up car)
eru is offline   Reply With Quote
Old 10-23-2003, 06:56 AM   #5 (permalink)
SoCal3S.com
xtremewlr's Avatar
Drives: 1995 3000GT FWD
Trader Rating: (8)
xtremewlr is an unknown quantity at this point
Default
Nicely done. You need to update yur sig now
Check out #vr-4 on irc.sportscarweb.com
Whats IRC??
xtremewlr is offline   Reply With Quote
Old 10-23-2003, 11:14 AM   #6 (permalink)
Hitokiri Battousai
Jeremy C's Avatar
Drives: A car that runs
Trader Rating: (47)
Jeremy C is an unknown quantity at this point
Default
Good Job Iceman!
You can be me wingman anytime!
Jeremy C is offline   Reply With Quote
Old 10-23-2003, 01:33 PM   #7 (permalink)
Banned from selling
Drives: 1998 3000GT FWD TT
SpeedFreakSteve is an unknown quantity at this point
Default
So is it on the road now... or you still have some finishing touches?
SpeedFreakSteve is offline   Reply With Quote
Old 10-23-2003, 06:35 PM   #8 (permalink)
I NEED POWER!!!!!
PR Stealth's Avatar
PR Stealth is an unknown quantity at this point
Default
Nice writeup Iceman3K15 (wipes a tear from his eye) I hope I go TT soon
www.3sny.com
1991 Dodge Stealth R/T TT**SOLD**
1996 Mitsubishi Galant Turbo **NEW TOY**
PR Stealth is offline   Reply With Quote
Old 10-23-2003, 10:48 PM   #9 (permalink)
AWD > RWD
SLguy's Avatar
Drives: 94 black SLTT & VR4
Trader Rating: (21)
SLguy Level 2SLguy Level 2SLguy Level 2SLguy Level 2SLguy Level 2SLguy Level 2
Default
hopefully we can get his car started again
first he'll go then he'll go then he'll go and pull up next to a honda and go
Black 94 SL Twin Turbo Automatic - 63K miles, < 1K on engine
purchased 3/2001, TT converted 6/2003
8.5:1 Arias Pistons, Pauter Rods, DR Stage 3 heads, 3sx td05 kit, EVOIII 16G's (currently set at 17 psi), PTC high-stall torque converter, shift kit, LSD, FMIC, 550cc injectors, walbro 255lph, 3SX single pass radiator, and supporting mods.
Black 94 VR-4 (The black wasp) - purchased 8/10/2009, 80K miles
Air Intake, Blitz SBC-iD @ 14 psi, 50 lbs of wasp nests removed
2004 Jeep Grand Cherokee Special Edition - Daily Driver
SLguy is offline   Reply With Quote
Old 10-24-2003, 10:42 AM   #10 (permalink)
mitsugtocars's Avatar
Drives: 92 VR-4
Trader Rating: (47)
mitsugtocars is an unknown quantity at this point
Default
Great job now lets see some pics of the engine!
Mine should be back up in the next week or two. I already have new parts. Like Fidanza Flywheel, 3SX Stage II clutch, 3SX SS Clutch Line, and the DSR pulley & Short Shifter are on the way. Also I have 2 WRX turbos that will be on their soon after I have the car running. I love upgrades!
mitsugtocars is offline   Reply With Quote
